Question about Yard Machines Mtd Yard & Garden Cultivator 31cc Clutch
Yard machines yard & garden cultivator 31cc fuel line diagram
Fuel line diagram
4 Suggested Answers
  • 61 Answers
SOURCE: fuel line routing yard machine 31cc cultivator
unit with primer bulb,,,,,line from gas tank with filter, goes to bottom of carb, from top of tank to suction side of primer bulb, from output of primer to tank return
Posted on Apr 29, 2010
Testimonial: "Thanks for the info, tiller runs fine. Phil"
2strokeguy
  • 183 Answers
SOURCE: 31cc yard machine garden cultivator.
Only 3 possibilities for no spark. First, are you using an inline spark tester to determine there is no spark? If so, here's your possibilities.
1. The on/off switch is shorted out.
2. There is a short in the wire(s) from the switch to the ignition module.
3. The module is faulty.
Dissassemble the engine cover far enough to access the module. There is a small wire that leads to a spade connector on the module. Disconnect this wire. Retest for spark. If you still have no spark, the module is faulty and must be replaced. If you now have spark, then the module is good, so back track the wires to the switch to determine if the wires are pinch or chaffed, or if the switch is stuck in the off position.
If you are not testing for spark with an inline tester, please, please go to Walmart or Pepboys or Autozone or NAPA or Sears and spend $7 to $10 on the tester....it will save you alot of trouble.
Good luck.
Posted on Sep 13, 2010
rycgl
  • 1545 Answers
SOURCE: I need a diagram for
Here is a parts breakdown for your machine (found under MTD) with parts listings, diagrams and prices.
http://www.partstree.com/parts/?lc=MTD&mn=21A-121R900
Posted on Nov 24, 2010
How does the gas lines run on my Garden cultivator
Fuel line will run from the fuel tank to a in line fuel primer bulb then to a small diaphram type fuel pump then to the intake
Sep 08, 2014 | Garden
How do i replace pull cord on mtd 31cc tiller
Remove your recoil housing. Turn the inside to see if spring is broken. If spring is good wind it up as tight as it will go without forcing it. Once you have it wound all the way then back it off one turn or until the eyelet meets where the rope comes out. tie a knot in one end and feed through both holes. Pull the rope through till the knot is tight then attatch your handle. Once the handle is in place slowly let the rope wind itself in. pull a few times to make sure your knot is holding and reinstall on engine
Jul 16, 2014 | Yard Machines Mtd Yard & Garden Cultivator...
I need parts for the IDC 400 31cc cultivator
ordertree.com has them for abt 50 dollar. part 753-04125, I believe its a mtd part. plus abt 10.00 shipping
Aug 25, 2012 | Yard Machines Cultivator
Installing fuel tank to 2 cycle garden caltivator yard machine
Remove the screws that mount to the engine and slide the fuel tank forward. Slide the fuel tank out of the rear mount and remove the fuel lines from the tank. Install the fuel lines into the new tank and install it in the 2 mounts that held the original fuel tank.
Jun 08, 2012 | Yard Machines Cultivator
I have a Yard Machrines by MTD Yard & Garden Cultivator 31cc: Model No.21A-121R900 Ser.No.1A246DG1150 and I need to replace the primer bulb. How do I do that?
hello l, how to change primmer bulb,,remove the two fuel lines making note which line came off where,use needle nose pliers to push the two ears down and pull bulb out,make note on where the long and short stem was at,go to the mower shop and get a new bulb and install,put lines back on, done start engine,,hope this helps,,
Jan 27, 2012 | Yard Machines Cultivator
I need a diagram for Yard Machines; garden cultivator; 31cc
Nov 24, 2010 | Yard Machines Cultivator
Cultivator won't start.
After sitting for that long the carburetor will gum up and not let gas through. Buy a carburetor repair kit and replace the diaphram and gaskets. Be sure to make a sketch of where the fuel lines are routed to. It's easy to forget where they went and a headache to try to figure out. If it has a primer button I would replace that also.
May 01, 2010 | Yard Machines Cultivator
Fuel line routing yard machine 31cc cultivator 21A - 120R000
Apr 29, 2010 | Yard Machines Cultivator
Yard Machines Mtd Yard & Garden Cultivator 31cc Clutch Logo
35 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
