Question about Vector VEC010S Jump Start System 300 Amp starting power
What is the correct amperage for the AC power charger?
I got a class to transformer power cord 120v AC 60hz 12 watt input output is 12 volt DC 6.0 what will that work on my Polaroid tDX 1930 B
Check Amperage of your Polaroidd and the power adapter. Same voltage but higher amperage might fry your Polaroid.
If won't work, you might buy one for Amazon
UpBright 12V AC Adapter For Polaroid TDX 01930B TV DVD Combo Charger Power...
May 12, 2015 | Computers & Internet
My transcend external hdd power unit is 5vdc .it has two usb one for power .i hv adapter that converts ac to 5vdc which is charger of my tablet.can i use it to power up hdd externally and connect another...
Without seeing the specs of the adapter it's hard to tell the voltage is correct but what you need to be concerned about is the amperage(mA) USB ports on computers only put out a max of 500mA per port the tablet charger could put out more than that.
Dec 04, 2013 | Computers & Internet
With a new motherboard installed, am still having problems with AC power cord and battery. I know battery is getting to end of it's life.Power cord will not power laptop by itself. Laptop will onl
Output of 19 Volts DC at 6.3 Amps is correct. (It isn't the Amperage you have to be concerned about so much. It is the Voltage. Voltage is correct)
Mounted on the motherboard of your laptop is a power correcting chipset.
This chipset senses when the laptop battery needs a trickle charge, or a full charge. It also senses when the laptop is to run straight off of the battery, or the AC adapter. (Charger)
With a Battery being at the end of it's 'Life Cycle', you may be overtaxing this chipset. Can't sense that the laptop needs to run straight off of the AC adapter. Tries to constantly charge the battery.
Replace the Battery.
Or the motherboard isn't worth poo-poo, and has a bad power correcting chipset.
(Don't care if the motherboard is new. Lemons are made)
Some examples of chipset's used in this mode, I am referring to;
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://html.alldatasheet.com/html-pdf/85156/VISHAY/SI4925BDY/183/1/SI4925BDY.html
For additional questions please post in a Comment.
[ Also would like to ask what the diagnoses was, for motherboard replacement ]
Regards,
joecoolvette
Mar 18, 2012 | Toshiba Satellite A75-S2112 Notebook
I have lost my lead to my acer laptop aspire5100 series model number BL51 19v .474Acan you help.I am a mature age person thanking you Pat
There are two solutions to this problem, Pat.
One is to buy the correct AC adapter (Charger) for the laptop.
Two is to buy an aftermarket AC adapter that will work for your laptop, but will also work for many other laptops.
1) http://www.usbphoneworld.com/acer-adapter-19342-65w-lc-adt01-aspire-5520-ac-acer-aspire-5100-ac-adapter.html?CAWELAID=950033775
The above is from a quick search. Your search may be better. Just put Acer Aspire 5100 charger, in your search box.
2) From another quick search,
http://www.atbatt.com/laptop-chargers/b/acer/m/aspire-5100.asp?utm_source=google&utm_medium=ppc&utm_keyword=Acer+Aspire+5100+Charger&utm_content=NAC-X90-22&utm_campaign=google0&gclid=CLeDr7qIlqsCFQ9S7Aodvn_TXA
Would also like to commend you for your intelligence.
Stating the Voltage, 19V, and the Amperage, 4.74A ,is a really intelligent thing to do.
(The charger MUST have 19 Volts for the Voltage. The Amperage (Amp's, or A), can be more)
Regards,
joecoolvette
Sep 11, 2011 | Acer Aspire 5100 Notebook
HOW DO I RECHARGE SPECIFICE CHARGER OR BY COMPUTER
By computer so that you will obtain the specific charger that you need.
plankw,
What laptop is it? Manufacturer name, and Model Number.
(Bottom of laptop)
Also,.....on the Bottom of the laptop is stated the Input, and Output voltage.
Your concern is the input Voltage, not so much about the Amperage.
(V = Voltage, A = Amperage)
Example;
Input: 12V2A (Sometimes printed as 12V~2A)
12 Volts at 2 Amperes.
The AC adapter (Charger) must also have the correct plug to fit the laptop's DC Power Jack.
(DC IN)
Regards,
joecoolvette
Apr 21, 2011 | Computers & Internet
So i lose my Literati charger right after my birthday! I cant find it anywhere and i found my old t mobile charger and it fits perfectly. But i cant tell if its chargeing and it wont turn on! Please help...
Stop!
There are no voltage and amperage "standards" for low voltage connectors found on devices made to run from an external "wall wart" or transformer type charger or adapter. Just because a connector "fits" does not mean the power is 1) the correct voltage 2) correct polarity 3) correct type (AC or DC) or 4) can supply the amount of power needed to operate the device.
You may have done irreversible damage to your device by literally "grabbing any old charger that fits" to power it. Obtain the correct charger - or if unable to find one; determine the characteristics needed by the device - those variables are listed in 1 through 4 above.
You may find adjustable power sources that allow 1) changing of tips to fit the device, 2) a selector to choose from a range of voltages, 3) a switch to select AC or DC output and 4) the ability to plug in the tip backwards so that the polarity reverses. The last thing needed, is to know how much current in amps or power in watts is needed by the device. The charger / adapter should be chosen on its ability to supply this power continuously - never choose a charger / adapter that provides less than any of the electrical requirements; otherwise damage to the charger or device may occur - and if left unattended, could overheat and cause a fire.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Computers & Internet
I was having problems with the car charger CA-051, then, I used a T-Mobile charger, at first time worked, after that, the GPS Maagellan was dead. Is it possible that I have to order a new battery? or I...
Using non standard chargers is probably the problem. If the battery has suddenly become sogged since using this charger then it may have done more damage than you want to know about.
Was it the correct polarity +ve Tip? was it the right amperage?
Magellan are specific in recommending you only use their charger and with reason, its correctly made for it.
You can try the new battery angle, but get advice on the charger.
As a small note.. Car chargers do NOT fully recharge batteries in GPS. Use an AC or USB charger. The car charger is a maintenance power supply. Always fully charge the unit prior to use and do not plug to car power until engine has been started.
These are standard rules with all non hard wired GPS and phones, ( but not always in the manual, have to have service and new sales someway!)
Please rate my help++++Thanks for using FIXYA
Aug 11, 2010 | Magellan RoadMateā„¢ 1212 Car GPS Receiver
Can i purchase an ac adapter charger i lost mine
yes, there's available ac adapter charger in the market according to its amperage.
Mar 28, 2010 | JVC AC Adapter/Charger (AA-V50U) Projector...
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
My tablet is not pluging in
Toshiba computers have a label on the bottom that displays the exact voltage and minimum amperage required to power the computer ("DC15V 3.0A", for example, which means 15 volts DC (direct current), at 3.0 amps. Each Toshiba AC adapter has a label indicating its output voltage and amperage capacity (for example, "DC15V 3.0A"). Important considerations for using AC adapters with portable computers:
The connectors must be compatible -- they must mate together correctly.
The voltage level must match exactly (a computer designed to run from 15 volts can be powered only by an adapter rated to produce 15 volts). If the AC adapter's voltage is higher than the computer's requirement, the computer and the battery may be damaged, If the AC adapter's voltage is lower, the computer may not operate correctly, or not operate at all.
The AC adapter must supply at least enough amperage (current) to meet the computer's amperage requirement. Otherwise, the computer may not run properly, the battery may not charge correctly, or may charge very slowly.
The quality of the power (ripple, noise and other factors) provided by the AC adapter must be very high. AC adapters from other manufacturers may supply sufficient amperage at the correct voltage level but the quality of the power may be poor, which can cause the computer to operate erratically, and could even cause damage to the computer. Whenever possible, use the correct Toshiba AC adapter for your computer.
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | Computers & Internet
Vector VEC010S Jump Start System 300 Amp starting power Logo
Top Vector Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Vector Electrical Supply Expert? Answer questions, earn points and help others
