Question about Brother Sewing Machines
F07 ..break speed of machine - Brother Sewing Machines
Why does my machine keep jamming?
Is this a mechanical machine you're running on low speed? The usual motor doesn't have much torque at low speed (unlike the computerized machines with stepper or servo motors that have full needle force at any speed), and this can contribute to jamming.
Also check to make sure the bobbin case is in completely and not wobbly.
May 25, 2014 | White Sewing Sewing Machines
Top thread breaking every two inches
Make sure that the tension is not too high. Also I recommend a high quality thread if you're using cotton. Signature cotton thread works great. Jukis tend to break lower quality cottons because of their speed, but they can handle lower quality polyester threads.
Mar 27, 2014 | Juki TL-98Q
Grinding noise and needles breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
since there is a grinding noise it would be a good idea to have the
machine checked
Sep 25, 2012 | White Sewing 1740 Mechanical Sewing...
A 1968 BROTHER SEWING MACHINE. PROBLEM IS THE FOOT
The carbons in the ceramic tube normally break away, you should not have any problem if you have a new foot control,
Feb 15, 2010 | Sewing Machines
Old kenmore runs at choppy when trying to sew
Lubricate the machine. All metal against metal places. This should allow the machine to run smoother. This is an older machine and may need to be run full speed for a while to let it break free.
Jul 24, 2009 | Kenmore Sewing Machines
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Embroidery machine needle breaking
make sure your top thread is feeding properly and not catching on the spool or twisting as it comes off the spool. When i use metalic thread, i put it in a small can beside my machine and it works great.
Jan 02, 2009 | Sewing Machines
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
