Question about HP Pavilion 533w (P9859AR#ABA) PC Desktop
Computer Beeping, something loose?
I have an HP Pavilion a1000y with windows xp. Just yesterday I tried to put the hard drive from my dell dimension 3000 into the hp. When I turned the computer on my screen stayed blank and my computer started beeping, very long constant beeps. So I put the origanal hard drive back into the hp but my computer continued to beep when I tried to turn it on. I found out that the beeps mean something is loose so I took out the ram and made sure I put it back in properly. Then I unatached the gray cable (sorry I'm not sure what it's called, one of my friends that has his own computer business told me to do this) and then reatached it. The power cord is plugged into the ram properly, so I'm not sure what else could be the problem. What else should I try? Thanks!!
  • 1 more comment
  • jada9505 Mar 11, 2009
    how do I remove the bios battery?
  • jada9505 Mar 12, 2009
    ok I put it back in but it is still beeping? :(
    o wow thats bad... so would getting more ram help?
  • 404 Answers
Looks like u've done most of the steps.
put everything how it was, change the ram to the next availble slot. remove power, remove bios battery "like a watch battery" wait 10min and put back on and power on see what happens
Posted on Mar 11, 2009
  • lotfi bouakaz
    lotfi bouakaz Mar 11, 2009
    well take out the cover of the case, locate it and use your nail to take it out or a screw driver.
  • lotfi bouakaz
    lotfi bouakaz Mar 12, 2009
    thanks for good rate, well at this point its to do with ram "memory" otherwise for fast fixing buy a new motherboard
Switched a vista hd to a xp hd and windows will not open
You can't do that, it just won't work. A hard drive with XP installed on it will be unrecognizable to a PC with vista already installed on it. You can either backup your XP drive by putting it into a compatible XP computer. Or you can buy on of these, which are handy. This let's you get the data to your new PC thru a USB connection.
Mar 26, 2012 | Dell Dimension E520 PC Desktop
Dell Dimension 8400 running xp has died. Can I put the hard drive into a spare slot in a Windows 7 PC to get the data off the XP HD?
Two Options:1. Yes you can as long as your Windows 7 PC has the correct connection for your hard drive. Most likely you need an IDE connection. If you have an IDE hard drive and the Windows 7 PC has an IDE connection, then you will need to make sure to "slave" the hard drive by moving the jumper on the hard drive to slave mode.
2. If your Windows 7 pc doesn't have an IDE connection, the purchase a USB to IDE cable adapter:
This way you can plug your hard drive into any computer through USB.
Best regards,AbdielComputer repair plantation
Oct 27, 2011 | Dell Dimension 8400 PC Desktop
I have 2 computers one dimension 3000 dell. on the drive is down. the other has no partions built in. is it possible to find the bios chip on the one computer, swap out to the other that has a boot...
it would probably be easier to just swap the hard drives. then when you go to boot, put in an OS install cd (Mac OS X ; Windows XP ; Windows Vista ; Windows 7) and it will walk you through the steps and partition your hard drive for you.
Oct 06, 2009 | Dell Dimension 3000 PC Desktop
I bought a HP Pavilion ze4300 laptop and it has Windows XP on it and it was working fine for the past three weeks. Yesterday I started it up and am getting a message: ''Operating System not found''. One of...
It could also be the conncetion came loose, which can happen with IDE hard drives if the laptop gets moved around a lot. Remove the hard drive and take it to an electronics store to have it tested, or if you have a friend with an external enclosure (2.5" IDE interface, they cost between$10-20) you can hook it up to another computer via the USB port
Sep 25, 2009 | HP Pavilion ze2000 Notebook
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Can't install WINDOWS.
Install the XP Pro first, install the necessary drivers etc. Then after that load the other disk for windows XP Home install it choose the drive to install the OS, install the necessary drivers etc. you will see two operating system while going to boot section of the computer.
Mar 11, 2009 | Dell Dimension 8400 PC Desktop
Hard Drive Question
That is your easest option. Plug the HP drive into the open connection of the dell hd ribbon cable. U may have to pay attention to the pin selects on the hd's.
May 21, 2008 | Computers & Internet
Installing Windows XP on new drive in HP a220n
Your new hard drive has a name, like Seagate, Western Digtail, bla, bla... Go to the Mfg's web site for your drive. Download the bootable floppy disk manager setup utilities. If you have a floppy disk drive. If you don't have a floppy drive most Mfg's allow you to make a bootable CD. Lastly or maybe I should have mentioned this first. Make sure your drive is pinned out correctly. I'm only guessing you bought an IDE drive which has a jumper for setting the drive as a master or a slave or a master with a slave.
Jan 03, 2008 | HP Pavilion a1220n (A1220NED904AA) PC...
HP Pavilion 533w (P9859AR#ABA) PC Desktop Logo
231 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
