Question about Valli & Valli H1003 Vcr Door Levers H1003 RP PCY 06A Anticato
Need replacement springs for vcr door handles
Change springs on garage door
It's is straight forward. Select a replacement spring with the same tension color as the original spring. The color is applied to one of the hooks. Above all thread the safety wire through the center of the spring.
Feb 02, 2014 | Stanley Hardware 730610 110 Lb Garage Door...
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
Hotpoint Door handle will not return to latched position
the spring in the door handle assembly is broken,the spring is replaceable seperatly.
Aug 22, 2009 | Washing Machines
2001 Ford Explorer Sport
Common problem on 2001 Ford Explores. The reason why your door handle doesn't unlock the door(can't be unlocked by remote either)is due to a broken spring located on the backside of the door handel INSIDE the door. True that your one(or two) of your small exterior springs on your door handle are broken(will cause your handle to flap) but this IS NOT YOUR PROBLEM. The door locks will work if there is a bit of tension holding the handle bracket up. I know it's hard to explain without pics. but here's the ONLY WAY TO FIX THIS. It's not that hard.......... Remove the door panel, only a few screws and a few more holding trim around exit handle then, pull out "snap in" clips on bottom. With a flashlight you'll see back side of door handle. To get to that area you'll have to remove one bolt holding a window frame. Do that(with window in up position) then slide down rail, out of your way. Now, get back to handle. With your light aimed at the backside of handle left slowly the door handle as normal, and you'll realize(while looking at the mechanism) that tension(pulling down of bracket) needs to occur in order for locks(manual and remote)to work properly. Trust me.....you'll figure it out. Once you do, get a spring(pen spring, 30 cent hardware store spring, any small spring!) and hook one end to bracket and the other end to ANYTHING(OUT OF THE WAY) below the door handle thus, causing SLIGHT tension. Try your locks...THEY WILL WORK! YEAH! Replace that one window frame bolt(try your window...just the make sure), replace door panel and your done. TOTAL COST: 30 cents or FREE(if you have a small spring) Ford dealers will charge $150 to $285! Yikes!
Jan 08, 2009 | 2001 Ford Explorer
Toyota ECHO REAR DOOR HANDLE problem
I have this same problem, and I removed the interior door fascia to examine the cause.
As mentioned, the moving, plastic part of the door handle has a recess that houses the return spring. Under stress (under too little stress, if you ask me), part of that plastic that surrounds the spring ruptures (tears), and the spring can no longer exert sufficient force to get the handle to retract flush against the car.
There is no way to fic that plastic part--you have to replace the entire handle. Searching for "Toyota Echo Door Handle" will find you a number of on-line sites that sell BLACK handles for under $7.00! The dealer wants something like $50-$70 for an OEM part, with the right color.
I have the service manual, and replacing these things is a *****! You have to use a TORX bit to remove the actual latch in the door, to get it out of the way.
There isn't actually any fixed linkage between the handle and the interior latch mechanism. When you pull the handle up enough, a plastic cam on the handle strikes a metal lever within the car door, forcing the latch to release the steel hoop. So once you can ACCESS the handle, swapping it out looks straightforward. The problem is, accessing it is a pain. Make sure you have a magnetic grabber handy for the hardware!
I have yet to find a cheap source for SILVER handles on the Internet (none of the Internet Junkyards have responded).
Aug 15, 2008 | 2001 Toyota Echo
Valli & Valli H1003 Vcr Door Levers H1003 RP PCY 06A Anticato Logo
206 people viewed this question
Top Valli & Valli Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Valli & Valli Hardware and Accessory Expert? Answer questions, earn points and help others
