Question about Garden
Oil light reset on cub cadet volunteer 08
Oil light is blinking and I have already changed oil and filter
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
  • 202 Answers
SOURCE: how do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Posted on Jul 08, 2009
SOURCE: I have a cub cadet lt1550 and the oil light is
The mower is programmed to remind you to change the oil every 50 hours. It will continue blinking for 2 hours. It will begin blinking again at 100 hours and every 50 hours after that. There is no manual reset.
Posted on May 25, 2010
SOURCE: how do i reset the change oil light on a 1040 cub
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Posted on Sep 01, 2010
My 04 cub cadet m60 tank with a 27hp Koehler just up and quits after 20 min. I just changed oil and filter and "change oil " is blinking. Help
I'm not a Cub dealer but the "change oil" light should reset itself after usually an hour of use. check the oil level for the no start. if it has an oil level switch and is low, there will be no spark.
Jun 01, 2016 | Cub Cadet Garden
HOW TO RESET THE BLINKING OIL LIGHT ON A CUB CADET RZT
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Sep 08, 2014 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Cub cadet trouble shooting
i think check for water in gas then fuel filter then rebuild carb thats all you can do and change plug if you havnt already
Jul 24, 2014 | Cub Cadet Garden
My Cub Cadet oil light keeps blinking. Ihave already changed oil and oil Filter. The oil indicator show a code number LA6' WHat is wrong with the oil Light?
have you ran it moer than an hour after changing the oil
is the light for oil needs changing or oil is low
if its for changing and you havent ran for more than an hour that may be the problem has to reset
Oct 04, 2013 | Garden
Cub Cadet shuts down, oil full but blinking light, runs like a champ til then
oil light says on for about 2 hrs from when it due to be serviced by the hr metre not when you have serviced
Apr 08, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
I changed the oil on my cub cadet lt1042, the oil light is still on
THE AIR FILTER SHOULD MAKE NO DIFFERENCE, THE LIGHT MAY BE AN OIL PRESSURE LIGHT NOT LEVEL LIGHT.
May 02, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Riding Lawn Mover with Kohler Engine - oil light stays on.
you need to change your ,and if you already have,the light come on evevy 50 hours to let you know to change your oil, the light will go out after about 2 hours,there is a way to reset it in your owner manual, I just unhooked my battery and it reset
Aug 20, 2010 | Cub Cadet Garden
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
