Question about HP Color LaserJet 3500 Printer
HP Colour Laserjet 3550 printing problems
HP Colour Laserjet 3550 - prints fine but recently more than a few pages and the output becomes blank pages.
Leaving device for a few minutes let you print again. Any ideas?
Fuser unit? Image drum? Something else?
Printer doesn't report any error messages and supplies status page
shows everything as fine!?
  • Anonymous Apr 27, 2009
    print quality is poort
    An expert whose answer gotĀ voted for 100 times.
  • 121 Answers
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Posted on Mar 22, 2009
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
My hp4600 is printing the first page blank and then the last page blank but inbetween those blanks it prints out the document fine, thought it was a driver issue so I updated it but the problem was not...
It is a problem with the Print Spooler which is creating a problem
the print spooler has got corrupted
need to do few troubleshooting steps
1.go to start menu on search button and type services.msc
3.Then find print spooler and stop and restart the print spooler
4.restart the pc
5.check if it works fine or not
6.if the same problem stays reload the operating system
Jan 11, 2011 | HP LaserJet 4600 Printer
My HP 3550 won't print black when it is out of a color.
restore the properties.... set as "print in grey scale" or "print color as b/w images"...
also if the print become less or more dark you can change the settings to print whit more intensity or less...
there is no necesary change all your documents as "watter ink" only change the print options to fade to black
May 15, 2010 | HP Color Laserjet 3550 Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
Printing Hp Laserjet 2550n
there is a clutch that stop/release the movement on the carousel,is located on the top right part of the carousel. remove and clean the STICKY CLUTCH.
Reinstall and ready to work
Mar 09, 2010 | HP LaserJet 2550n Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
HP Color LaserJet 3500 Printer Logo
404 people viewed this question
Ben Johnson
