Question about Hotpoint Washing Machines
Fix paddles on WDD960 WASHER /DRIER
REPLACE PADDLES
ghappliances
  • 126 Answers
SOURCE: hotpoint BWM 129 washer
ARE THE PADDELS BREAKING OR MELTING.
Posted on Sep 15, 2008
SOURCE: One of my drum paddles
i had the same problem and sourced the parts from ebay - 3 for £9.99
Posted on Jan 04, 2009
SOURCE: ASKO washer WL6511XXLPP
Purchased ASKO Washer WL6511XXLP and Gas Dryer with pedestals, 12/01/09. It threw a drum paddle during 2nd. wash cycle. Damaged several articles of clothing.
ASKO replaced the paddle 2/19/09 after a lot of phone calls (lip service from the ASKO 800 #). They claimed the part had to come from Sweden (reason for delay).
Washer threw another drum paddle during 4th. wash cycle. Damaged several more articles of clothing. We have made no claim for the damaged clothing, the retailer has been cooperative.
ASKO has promised to replace the washer after the retailer we purchased the washer from, strongly encouraged them to do so. We are still without a washer (03/23/09). My wife and I are retired, I am 76. Point being; we do not abuse washing machines and we don't like going to a launder-mat.
I know this is not the venue to address this problem, but am at my wits end.
Posted on Mar 23, 2009
SOURCE: Washing Machine Paddles
I have a bwm129 and two paddles have broken of I can get two more paddles and they look like they just slide into place but should I open the back up to see if there are any of the broken retaining hooks behind the if so how do I do this?
Posted on Jul 11, 2009
SOURCE: Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Posted on Apr 01, 2010
Testimonial: "Yes, this was the correct solution for this particular model of W/M. Many thanks!"
Frigidaire Washer GLTF2940FS2 How do I remove & replace washer paddles
Thank you for your inquiry, Dawn Leonard!
From what you have described you want to remove your washer paddles and replace them on your Frigidaire washer. I am unsure which paddles you are referring too? Could you provide further information, please? With that I would be able to assist you further. -Matt
Feb 22, 2015 | Frigidaire Washing Machines
Drum paddles replace
Assuming the paddles are attached with nuts/bolts I would suggest using Locktite. If that is not an option, lock washers. If the paddles do not attach using nuts/bolts, invest in some high end epoxy.
Dec 16, 2013 | Washing Machines
Coins inside Kennmor dryer drum paddles
You will need a thin putty knife. Run the drier to get it warm inside. Use the putty knife to slip under the paddles and lift them just enough to let the coins drop out when you rotate and raise the drum on that side.
Aug 23, 2011 | Kenmore Dryers
I need to replace the paddles on the inside of the drum - is this a difficult job to do - if not i will go ahead and order the parts myself as an engineer call out is to expensive
Hi if you let me know what make & model washer you have I will let you know if its a easy fix or not some paddles you can fit yourself easy some you should not try
Jul 26, 2011 | Hotpoint Aquarius WF210 Front Load Washer
The spindles that you attach the paddles to is leaking a black lubricant or something like that. I was making a simple sweet dough. By the way, I NEVER bake in the bread maker. I only use it to knead the...
Your machine has a lubricating grease that is under the small gasket or washer at the bottom of the pan under each paddle. After a lot of use the little gasket can fail and the grease can get get past the gasket and into your bread. The best thing to do is either replace your pan with what is called a "pan assembly which will include everything but the paddles. If you decide to do that be sure to keep your paddles. The other choice of course is to replace your machine which might not be a bad idea if your machine has been used a lot because you would have a new pan assembly but older parts may begin to fail such as the drive belt. Bread machines aren't all that expensive anymore so you may want to go ahead and replace especially since you just use your machine for making dough.
Feb 08, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
B2300 Bread Machine: Good morning - Both paddles in the machine come of...
I am experiencing the same thing. I've spoken with a rep at 1-800-231-9786 and they said that if my machine was still under warranty they would replace the paddles and the pan. I purchased mine in 2007 and therefore my cost to replace the above would be $68.00 Cdn. That's getting close to purchasing a new machine. Does anyone have any ideas... wrap the rotating shafts with plumber's tape or anything else that might ensure the paddles will stay in place?
Linda
May 16, 2010 | Black & Decker B2300 Bread Machine
How do you fix a paddle on hotpoint washer
these paddles are easy to fit ... simply slot in and push towards back of machine untill it click locks into place ...
Jul 17, 2009 | Hotpoint Ariston AW125 Front Load Washer
Drum paddles falling off
until you post the statement again and include such vital details like make model year type of equipment etc and photo then nobody has any idea of what you are on about
May 05, 2017 | Zanussi ZWF1420W Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
