Question about Goodman Heating & Cooling
Blower moter is bad pcb030100-1 - Goodman Heating & Cooling
What fuse is the fan blower moter 2005 rendevous
It is probably the blower motor resistor located on the passenger side
under the dashboard that is bad not the fuse.
Nov 17, 2012 | 2002 Buick Rendezvous
Blower moter will run only on high
The most common cause is a bad blower motor resistor. It attaches to the blower motor and controls fan speeds. It's typical for a bad resistor to lose 1 speed at a time until you are left with just 1 speed as you are experiencing.
Oct 30, 2011 | Cars & Trucks
Heat and air works but blower will not blow
CHECK FUSES OR COULD BE BLOWER SWITCH.CHECK POWER TO AND FROM SWITCH.IF THERE IS POWER TO BLOWER MOTER THEN BLOWER MOTER MY BE BAD.
Feb 18, 2011 | 1995 Pontiac Bonneville
Front blower will not blow. checked all fuses all ok. did not make any noise before going out. what could it be?
A common cause for this is a bad blower moter resistor. The resistor is located under the hood on
the firewall to the right of the blower moter. Hope this helps.
Dec 06, 2010 | 1999 Chevrolet Express
My heater motor only works on high
A bad blower moter resistor can cause the blower to default to high speed only. The resistor is
located behind the lower right side of the dash on the heater box just left of the blower moter.
The fan switch can also cause this problem, but more often then not it's a bad resistor.
Hope this helps.
Nov 22, 2010 | 2006 Chevrolet Colorado
Replaced the climate control and blower wont work
f that just put power to the blower moter and see it it runs if you pull the relay jump a wire across the terminals with it out and add a ground wire to the case of the blower to another spot on the chasis if it still does not run your blower switch may be bad dont worry just run a toggle switch to a good blower moter
Feb 28, 2010 | 1998 Pontiac Grand Prix
While driving my 2004 Yukon with the heat/defogger on high it suddenly went off and no sound of the blower being on my windows then began to fog up. I thought it was the fuse so I changed it but the...
gms are notorious for having a bad ground too the blower moters,try running a ground from the neg side of the battery too the blower moter!!
Feb 28, 2010 | 2004 GMC Yukon
Air and heat dont blow hard any more
Sounds like you have a bad blower moter resistor.
The resistor assembly is located on the heater box module
under the dash near the blower moter. Hope this helps.
Feb 19, 2010 | 2000 Chevrolet Silverado
Blower motor 94 dodge intrepid inop
1.disconect battery
2. remove lower right undre panel silencer duct
3. remove the blower moter connector from the resistor block
4. squeeze the blower moter wiring gromment and push the gromment throw the blower moter housing cover
5. remove blower moter housing
6.romove the screws holding the blower moter down
to put back on do the steps back werds
Jan 03, 2009 | 1994 Dodge Intrepid
Blower fan
it sounds to me like your blower moter resister or your blower moter switch are going bad both are right under the hood next to the blower moter one has 2 witers on it the other has 4 it usuley on the pass side right near the window
Dec 03, 2008 | 2000 Chevrolet Venture
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
