Question about Craftsman Garden
Wiring diagram for sears lawn tractor 24 hp model 917.275683 needed for pto switch
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 246 Answers
SOURCE: I need an electrical diagram of the snapper lawn tractor
Hello:
Try this Site Addy;
>>You can View a Breakdown of the Mower at this Site Addy; http://www.snapper.com/manuals/ . Enter your Model Numbers in the Box Provided and Click Find Manuals. Select Illustrated Parts List from the Manual List Provided. Now Download the Manual for Online Viewing.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
Posted on May 26, 2009
mowerman1857
  • 389 Answers
SOURCE: need a wiring diagram for a craftsman lawn
http://c.searspartsdirect.com/lis_png/PLDM/P0502131-00001.png
This will take you to a wiring diagram
Posted on Sep 20, 2009
  • 13 Answers
SOURCE: wiring diagram for craftsman lawn tractor model
944.601140 Sure this is right number?
Posted on Sep 29, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
Www managemyhome com
bad safty switch or shorting pto if pto replace it but i think one of your safty switches is bad
Aug 26, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
Sears tractor wiring diagram charging system
google your model # (usually found on label under the seat). This should take you to sears site. click on manual tab and download the users manual. wiring diagrams should be in the manual.
Jul 25, 2013 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
On John Deere lawn tractor when we pull the yellow button up to engage the blades to start spinning, they dont move.
If you have an electric pto switch, the switch, connecting wire from the switch to the pto clutch, or the clutch itself could be defective. You can check the switch and wire with an ohm meter. You can also check for proper voltage at the pto clutch plug.
Sep 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When I pull the blade lever the blades do not turn. Found that the trottle wire to pto is broken. Need instructions and a diagram on how to fix it. Thanks
just wire it back together, you don't have to worry about crossing the wires up. because it's just a hot and ground for a coil to magnitize to ingage the pto clutch.
Jun 21, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
WHEN I PULL THE BLADE ENGAGEMENT BUTTON, THE BLADES DO NOT ENGAGE.
Check the connector at the switch that engages the blades (PTO switch). Pull it off, make sure the pins are clean, and replug it firmly. Do the same at the connector at the PTO clutch, which is mounted on the engine pulley. Look for a broken wire at the same time.
It's very possible the PTO switch itself could be bad. It can be tested with an ohmmeter if you understand the internal operation. If not, just remove it and take it to Sears to get a replacement.
Jun 09, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Looking for wiring diagram for sears tractor
Sep 07, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Blades won't engage. OK-I need a pto clutch
A switch should only be about $25. Before you spring for a new PTO assembly, take your switch out and take it to a shop and have it tested. I may just be a bad switch. Don't bother taking it to Sears though. Take it to a shop that works on Husqvarna and/or Poulan Pro. (Both basically same as Craftsman). DO take the model number from under the seat with you.
Jun 24, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I need WIRING diagram for model #917.2155915 tractor
you can go to sears website type in your model number and it has parts breakdown as well as a wiring diagram
Jan 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine starts, but stalls when clutch is released.
The is a safety switch located underneath the mower, in the dashboard area. This switch will not pass voltage to the ignition system unless the pedal is depressed, or the deck is not all the way up. However, your culprit is most likely the pto (power take off) switch on the dash that engages the blades. It will not allow the mower to start, if pulled, and if faulty will shut off ignition power when you release the pedal. First. You'll need a volunteer to sit on the mower and operate the controls.  Now put the deck down and with the pedal depressed start the engine. Nothing should happen, if it does replace the deck switch Sears part number #176138 mentioned above. Now raise the deck and release the pedal. Again, nothing should happen. Same solution if it does. If nothing happens on both tests the switch is ok. NOW. Behind the dash, find the pto switch, and squeeze the sides, depressing two clips that hold it in the dash. You should now be able to slide it though the dash, wiring attached. Unplug the switch. With pedal depressed, deck up, someone sitting on the seat, start the mower. Now release the pedal (making sure to block the wheels and have the transmission handle is in the neutral position. If the engine continues to run, you found the problem. Replace the PTO switch. Sears part number # 174651. Also, check the plug to the pto, ignition and deck switches for corrosion as this is a common problem, though not likely to cause yours, it could. Good luck, and please let us know the outcome, good or bad. Thanks so much.
Nov 12, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
42 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
