Question about Sony VAIO VGN-TXN15P/B Notebook
I just upgraded Sony vgntxn15p laptop from Windows XP to Vista. Having problems with install of TPM and bios update.
My dell inspiron laptop model 9100 Windows xp Pentium 4
Dear I think that u have problem with display driver ... U need to update bios which is available on site then install display driver hope this will help u ... U hv posted less information in ur question
Dec 04, 2014 | Dell Computers & Internet
Tpm not found or tpm problem on acer aspire 5520g
solution is try to re install the Windows Vista back and see whether the TPM will show missing. sometimes thats happening to most of the systems. when you try to put another windows thats did not came with the product, you will miss some functions such as drivers, battery not charging, internet not working, audio not working and many more. so put back windows vista and whether your problem still existing.
Sep 08, 2012 | Acer Aspire 5520-5908 Notebook
Upgrading windows vista to windows xp in presario 115DX
You cannot 'upgrade' Windows Vista to Windows XP - that is technically a 'downgrade' and would need you to save all your user data on Vista then format you Windows drive then do a clean install of Windows XP.
If you try to install XP over the top of Vista you will have lots of problems because of the difference in architecture and boot manager changes.
The only alternative would be to set up a dual-boot installation where you install XP alongside Vista but would be best done on either a separate disk partition or on a second disk. Normally such a dual-boot configuration would start with having XP installed then adding Vista as the second operating system.
Jan 11, 2012 | Compaq Presario CQ56-115DX Laptop
Install xp on sony series nr
The BIOS doesn't care nor detect the installed OS and should only be upgraded if you are having BIOS issues.
The old adage "If it works don't try to fix it" certainly applies here.
Sep 07, 2009 | Sony VAIO NR Series VGN-NR485E/T Notebook
Need BIOS update for my MX6424 Gateway with Win XP
If your board is not supporting the 2gb memory module, it won't make any difference by upgrading the BIOS.
Aug 27, 2009 | Gateway MX6424 Notebook
How i can install xp sp2?
for bios update go to manufacturers website but to install xp sp2 on this lappy you will have to install third party raid driver and legacy device driver that you can download from www.download .com
May 09, 2009 | Computers & Internet
Hello sir i have COMPAQ CQ50-106AU laptop . sir my laptop had come with free dos environment and than i had installed xp on it but sir one day i installed vista in it and downloaded all the supported...
Well unfortunitly on this issue your going to have to choose what operating system you want to use hence you upgraded your bios with vista. #1 never do that. #2 go to the manufacture site download the bios frimware and flash it again.
#3 sir my name is Rulds2008 and I am here to assist you, I am looking forward to seeing your good rating for me.
May 05, 2009 | ATI RADEON 9200 Graphic Card
Windows Vista
hi there
There is 2 ways to do this, firstly you can create a floppy disk with the updated bios flash file on ( not recommended to a novice ) or reinstall XP and updated the bios by downloading it from the manufacturers website and installing it that way. After that you can install Vista.
good luck
Jan 21, 2009 | Toshiba Satellite M35X-S1142 Notebook
Does the fj270 recovery disk from ebay make the computer like new with a blank harddrive?
I am assuming you are going back to XP?
You will run into one major problem with this process, Vista is based of Windows NT which uses a NTFS file system. XP uses the old file system of FAT32, so just wiping the hard drive probably won't work. You will have to go into your partition and re-partition your hard drive before you intall the recovery disk.
If the recovery disk is designed for your computer then yes it will restore it to all factory defaults (including drivers and software that originally came with it.
If you are not sure how to do the partition then let me know I will try to guide you through it.
Mar 27, 2008 | Sony VAIO VGN-FJ270/B Notebook
Sony VAIO VGN-TXN15P/B Notebook Logo
111 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
