Question about Shindaiwa Backpack Blower - EB802
Shindaiwa blower runs good for 15 minutes then shuts off
Shindaiwa leaf blower EB8520 loose power every 5 secondes for 5 secondes
Sounds like you are running it with the choke on - is it spitting black smoke?
Jan 12, 2013 | Garden
My blower runs good for first 15 minutes, then will quit
Will it start again after you let it cool off? Run it till it quits then immediately remove the air filter and cover and give a quick shot of carb cleaner into the carb and attempt to start. If it wont start on a prime but will start later after you have let it cool, then does the same thing ( dies after 10 or 15 minutes of use) then it is likely the ignition module going bad.
I suggest you find a serviceing dealer to verify that the module is failing. Husqvarna warranties thier ignitions for life on most models.
Oct 08, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
Do you use 2 cycle or 4cycle oil for mix in shindawai blowers
Not knowing what model blower you have, I do know that Shindaiwa manufactured both two cycle and 4 cycle blowers. In either case, you run the required 50:1 ratio. I would also recommend using the Shindaiwa branded oil since it is formulated to run in their equipment at that ratio.
Other manufacturers have 4 stroke blowers on the market that run "straight" fuel because they have an oil sump for the engine oil, much like a 4 stroke lawnmower. However, that is not the case with Shindaiwa's 4 cycle design which still runs "mixed" fuel.
Feb 20, 2011 | Echo Back Pack Blower Rack Fits Stihl...
I have a Goodman GMH950904CXAC. Thermostat calls for heat. It comes on and runs fine for about 5 minutes, then the circulator blower shuts off, but burners and draft blower still run. After another 15...
4 flashes is an overheat situation most likely caused by the blower not blowing. The blower relay controls the blower function. It is part of the circuit board. I suspect a new board will take care of the problem if you don't find a lose wire or something simple.
Feb 27, 2010 | Goodman Heating & Cooling
Shindaiwa Blower - when throttle pushed, engine sounds flooded and it dies. any thoughts on how to fix?
Its not flooded- its lean.
Heres a way to test me. Try to give it throttle but keep it running. At the same time slowly close the choke. does it run better as you close the choke? Does it run pretty good on half choke?
Rebuild the carb, replace the fuel lines and fuel filter.
Dec 20, 2009 | Garden
The blower stops working
;blower motor gets to hot and shuts down. after cooling it runs again . this is bad brgs or tight brgs . you can try oiling brg or replace the motor . if older like you said i would repl the motor , this is a common problem as we repl a lot of older motors.. mm
Dec 12, 2009 | Cooktops
Shuts off after about 15 minutes
If it is gasoline powered, ensure mix is correct if 2 cycle, check exhaust for carbon blockage. Either will cause overheating.
Mar 27, 2009 | Garden
The blower will not shut off at the end of a heat cycle
replace the circiut board or the blower relay. It will probably a board.
Nov 24, 2008 | Heating & Cooling
Shindaiwa Backpack Blower - EB802 Logo
61 people viewed this question
Top Shindaiwa Garden Experts
Dennis Key
Dennis Key
john h
Are you a Shindaiwa Garden Expert? Answer questions, earn points and help others
