Question about Stanley Bostitch CPack1850BN 2-Inch Brad Nailer and Compressor Combo Kit
Belt replacement on bostitch cpack 1850bn
How do i replace belt
2 Suggested Answers
  • 25 Answers
SOURCE: I do not know how/or
http://www.docstoc.com/docs/56973363/Factory-Reconditioned-Porter-Cable-C2002R-Oil-Free-UMC-Pancake-Compressor
Usually when buying new/reconditioned it doesn't have the female coupling installed.You need to buy it separate and a roll of Teflon tape.On your model its to the right of the psi adjustment knob.Take a look at the link,it connect to the 2 brass peices on the front right.Good luck.
Posted on Feb 22, 2011
How to disassemble stanley bostitch sb1850bn nailer
very carefully as springs like to FLY then hide from us . but does it need disassembled . what is it not doing , or doing wrong .
Aug 31, 2015 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
How do I remove the trigger valve assembly?
i would just look on the box or go to the company website and ask them
Sep 18, 2013 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
Replace seals on bostitch sb-1850bn pin nailer
First make sure to get your parts from a service center or directly through the Bostitch Servicenet site online,,,shipping is a little high but you will be getting factory spec parts,,I usually get two of each of parts that I need just in case
Jun 30, 2013 | Air Tools & Compressors
Replace driver unit bostitch sb-1850bn
try going to a service center or order direct from the Bostitch Servicenet website
Driver stays out after firing
You probably have a worn air seal. Or perhaps some pneumatic tool oil might do the trick. A few drops in the air outlet then bumb some nails into a piece of wood.
Apr 18, 2013 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
Stanley Bostitch compressor cpack model runs and runs but won't fill tank.
check for any air leaks and fix as needed. then look for oil coming from cylinder heads , if oil is coming from heads you have blown head gaskets ,it wont build pressure like this. you might also check the pop off valve to be blown open. push the pin in and see if air starts to build up then. If so get a new valve.also check the drain valve under the tank and make sure its closed.
Apr 17, 2013 | Air Tools & Compressors
I received a reconditioned Bostitch 1850bn and compressor. None of the fittings seems to work with the nailer.
Get the proper fittings at your local auto parts store. They come "A" "B" "C" "D" style and some others. Yours is probably a "A" but take the one you want to match with you.
Apr 05, 2011 | Garden
I do not know how/or where to insert the end of the hose to the Bostitch 1850BN compressor.
Feb 22, 2011 | Stanley FactoryReconditioned Bostitch...
New model sb-1850bn will not operate at all. Oiled it lightly before trying to use. Air comes out around trigger.
If the air is coming out of the trigger when you try to drive a nail, most likely the driver is broken.
Bostitch nailer have a 7 year warranty on them so, take it to a Bostitch service center and have it repaired there.
Dec 16, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
I have a SB-1850BN Bostitch finish nailer that no longer shoots nails. I think it may be a o-ring in the cylinder but not sure. Is there an easy fix for this situation?
Generally speaking an O-ring kit will resolve this type of problem. Check with your local lumber yards that sell Bostitch products. They may have a Bostich Day at which, for a purchase of nails or some other Bostitch product, the manufacturer will give up to 2 tools a quick overhaul including replacing the O-rings.
Dan
Jan 11, 2010 | Stanley Air Tools & Compressors
Stanley Bostitch CPack1850BN 2-Inch Brad Nailer and Compressor Combo Kit Logo
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
