Question about Music
HOW TO CONNECT UB124FX TO A AMP
HOW DO I CONNECT TO A AMP
Peavey classic chorus 1991 -how do you connect a distortion pedal the power amp jacks at rear tried affects loop in front bid drop in power-do you connect same way as effects loop with send /return
Pedals operate at a different level then rack units that go in the effects loop.
It needs to go in front of the amp input. Guitar to pedal to amp input.
Nov 12, 2016 | Peavey Music
How do I connect a peavey 32fx mixer to a peavey pv3800 ampflifier
You should be able to connect the XLR l&r outputs to the amp or the 1/4" l&r outs to the amp. Check out the manual here.
http://assets.peavey.com/literature/manuals/FX_Mixers.pdf http://assets.peavey.com/literature/manuals/FX_Mixers.pdf
Nov 03, 2015 | Peavey Music
How do I connect my roland piano 5500 to an amp
On the rear of the piano there will be two 1/4" jacks labeled Output Left and Right. One will be labled Mono as well. If you are using a stereo amp, use both, and if a mono amp use just the mono output. If your amp is a guitar type, connect a shielded cable with 1/4" phone jacks such as you'd use with an electric guitar from these jacks to your amplifier. If you are useing a home stereo amp, you will need a cable with 1/4" phone jacks from the piano to RCA phono jacks on the amp end.
Oct 08, 2014 | Roland HPI-7F 88-Key Digital Piano -...
No sound when connect guitar
have you checked the speaker leads in the back to make sure they are hooked up> if so, you have power to amp? Volume knob turned up? is guitar cord good? (try it in a different amp , or check w/ an ohm meter) . Does the guiter have active pick-ups? If so, is battery good? and last, is the volume knob on guitar up" try all that and get back to me
Jul 18, 2014 | Behringer V-tone Gm108 15w Modeling Guitar...
Amp and chorus pedal
You'll need 2-3 INSTRUMENT CABLES to do this. There are TWO ways to try your connection to make it work:
FIRST WAY: try to connect it to the FRONT of the amp. DO NOT try to connect the pedal to the rear of the unit where it says "FX INSERT." Use one cord from your instrument to the "IN" port on the pedal. Use the second cable to run from the "OUT A" port from the pedal and connect to the "INPUT" on the amp itself. This should work without fail. This is the easiest way to see if the pedal is even working correctly or not.
SECOND WAY: If you want to loop it through the back, then you'll need two (2) cables (instrument) to do this. One cable to go from AMP "Insert" to the "IN" port on the pedal. One cable to go from the "OUT A" on the pedal, and back into the "Return" port on the amp. If neither way works, then you've likely gotten a bad pedal. Unfortunately, Behringer pedals are not known to be as high quality as some of their other gear. Best of luck!
Apr 11, 2014 | Behringer Music
I am in a ukulele ensemble of 8. We all have electric pick ups in our ukes. what is the best way to connect to one amplifier, eg; using a mixer ?
It can plug into a guitar amp or PA system both. If you use an amp, you could hear yourself alone through that, then output jack "power amp out" to PA or put a mic in front of it from the PA. If you don't use an amp, it can plug into the PA but, you would only hear the 8 pieces together and have no way to hear yourself seperately.
Mar 29, 2014 | Music
I want to connect my amp to my pc
use a mini adapter to a large one.(3.5 to 1/4) or mini headphone jack to 1/4 headphone jack.plug a male3.5 into your outgoing headphone jack or from the pc convert the other end of that cord to get you to the proper size or 1/4 head phone jack.the primary cord from the pc needs to be a male to female cord.they make adapters that will get you the rest of the way.3.5 mini male to 1/4 phono female.then you plug your amp in to the 1/4 female.wala
Jun 05, 2012 | Peavey Vypyr 30 30W Guitar Amp Head Black
What kind of cable do you need to connect a Kurzweil K2500S to the amp?
Hi. You can use standard 1/4 inch jack to jack audio cables (ordinary guitar leads will work fine) to connect the MIX outputs to a keyboard combo amp. If the amp only has a mono input, just use one cable from the MIX output marked L to make the connection. Remember to keep the amp volume turned down until you have plugged in the cable(s) from the K2500S. All best.
Apr 09, 2011 | Music
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Music Logo
21 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
