Question about Whirlpool Duet GHW9150P Front Load Washer
I have water leaking from inside the refridgerator (top/back side). Do you know what might cause this and how to solve it? Thanks ...
  • Pete4 Mar 14, 2009
    I tryed what you said and it worked excellent!!!
    Thanks for all your help.
    I really appreciate it!!!!!!
  • 163 Answers
Your drain is clogged.you may have a catch for your drain where you see leak coming from.that may pull off and you can see if their is trash build up in it.you are going to need to take the panel off the back of freezer.inside back of freezer you will see screws.they will need to come out,if you have ice maker that will need to be removed also.once back panel is off you will see your coils,beneath the coils it will most likely have a sheet of ice.tturn machine off and take a hair dryer and defrost the ice.once ice is gone take a cup of hot water and run thru drain to see if unclogged.repeat if drain is not clear.the ice in drain tube will eventually unclog.I use a steamer.much quicker.
Posted on Mar 11, 2009
  • mike cooksey Mar 14, 2009
    glad I was able to help. Have a wonderful day.
Ge monogram has water droplets in refrigerator side just along top right corner edge where top door gasket closes against refridgerator. Refridgerator seems to be holding temperature. Condenser is above...
The gasket may have worn some causing an air leak,.and you
are seeing water condensation from the leak. Try adjusting
the door hinge. Close the door on a piece of paper and see if
you can pull the paper out. Adjust the hinge until the paper is
tight.You may have to adjust both hinges to align it properly.
Feb 08, 2018 | GE Monogram Side by Side Refrigerator
Our refrigerator has started to leak water outside the refrigerator in the front. What could be causing this?
from inside refridgerator, or from below?
could be your condensation drain pan or the tube from the refridgerator to the condensate drain pan is stopped up. Have to take lower access panel off back of unit.If it has an icemaker, the water line could be leaking.
Mar 14, 2010 | Whirlpool 18.2 cu. ft. Top Freezer...
I have a slow leak from a coil in the bottom right hand side of the refridgerator
Inside or outside? because if inside it will soon if not already pull air and moisture into compressor and oil. If it is worth a couple hundered dollars or bid a price it is worth fixing if not the it is time to go shopping. I really hope this solves your question. If someone knows where the leak is it could be fixed easy on the condenser on the underside but the cold side requires a lot of work., Thanks Sea Breeze
Feb 11, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Refridge leaking water inside it...
The condensate drain begins inside the freezer compartment behind the back panel and at the bottom of the evaporator coils. Every time the refrigerator defrost (about 3 times a day) the water needs to flow out the bottom of that pan in the freezer and into a plastic drain pipe to the bottom of the refrigerator into a pan on top of the compressor or side of compressor. Sometimes the drain is blocked inside freezer and there is a buildup of ice. But sometimes it is blocked near the opening that leads out of the fresh food compartment and then down to compressor tray/pan. If the blockage is near that exit then you will see a trail of water running down the back of the fresh food compartment and settle in bottom. The only solution is to slowly and carefully remove the drain pipe from the back and inside of refrigerator and clean it out. Let me know how you are doing on this and I will be here to help,Thanks Sea Breeze
May 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Leaking inside refridgerator
not shure as to the design of that brand, but it is usually caused from a bloked up drain
Oct 25, 2008 | GALAXY Microsystems 63702 Top Freezer...
Refridgerator Leaks
I can't find this model number anywhere and am unfamiliar with the "Evolution" series. However, if it is a top/bottom unit (freezer on top, fridge on bottom) it sounds like you have a clogged drain.
If you pull the back panel off inside of the freezer (where the evaporator is housed) you will see a drain hole, usually in the rear center) that is probably full of ice. If this drain is plugged, it will cause the water to back up into the refrigerator, usually onto the top shelf or under the veggie bins, and possibly onto the floor.
You need to clear it out, and make sure that water flows through it freely, to the pan underneath the unit. The best way to do this is with a hair dryer and a copper wire, but be careful not to melt the inside of the freezer with it. When it's clear, you might want to take a hose and blow through it to make sure there's nothing trapped inside.
Please let me know if you need any further help with this issue.
Mar 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
