Question about Casio fx-300ES Calculator
How to get my calculator back to default Mthlo setting
My calculator on the graphing section shows only quadrant 1 and is zommed in. How do i get it back to default?
Press the ZOOM button and then select ZStandard to reset the window settings. Alternatively, press the WINDOW button and set the window values as desired.
Sep 07, 2011 | Texas Instruments TI-83 Plus Calculator
My TI-89 calculators finance app is giving me the wrong answers by a few 1000 or so and increases how far off it is the larger the figure
Make sure your decimals are set to the correct number.
And also you can perform a factory reset on the unit to make sure all is back to normal.
Just be aware that it will delete any information which you have stored into your calc.
Resetting
After using the TI-89 and changing modes several times, you may set the calculator back
to all default modes by pressing 2nd 6 (MEM), F1(Reset) and 3 or by highlighting
3:Default and pressing ENTER. To reset all memory press 2nd, 6 (MEM) then F1(Reset)
and select 1: All.
Feb 23, 2011 | Texas Instruments TI-89 Calculator
Someone messed with my calculator yesterday and today it highlights the word busy. I can't get it to work.
Best is to remove the batteries for a while, which should reset the memory and default to the factory settings once you place them back in and power it on.
Dec 08, 2010 | Texas Instruments TI-89 Calculator
Hey there, got somehow on some setting just
You can do exactly as you did to setup Fix, but instead of choosing [6:Fix], select [8:Norm].
To reset the calculator to the default configuration, you can do as follows:
Dec 05, 2010 | Casio fx-300ES Calculator
Aqccidentally press some button and 'fix' symbol appears
You have set the calculator to a fixed number of decimal places.
To reset calculator, easiest way is just to go back to the defaults - SHIFT, 9, (CLR), 3, (All), =, (Yes)
This will clear anything you have put in memory
May 29, 2010 | Casio FX-115ES Scientific Calculator
Setting the default value of my calculator to display decimals
Since you bent on deactivating the very features that make your calculator so versatile and so powerful, here it is.
Press [SHIFT][MODE][2:LineIO] and you will see no more fractions, nor radicals etc. You asked for it.
Hope it helps.
Oct 18, 2009 | Casio fx-300ES Calculator
Casio FX-115 ES: SIN,COS,TAN (answer isnt correct)
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
Sep 16, 2009 | Casio FX-115ES Scientific Calculator
Someone put my calculator in French. How do I get English back?
First push the APPS key. A long alphabetical list will appear and in the list will be various languages EXCEPT English. Scroll down and pick any language--say Espanol --and hit ENTER. The Texas Instruments screen will appear and you will have a choice of pressing 1 for Espanol or 2 for English. When you press 2 the next screen that comes up will say ENGLISH DEFAULTS SET. Just press any key and you're set to go.
Mar 26, 2009 | Texas Instruments TI-84 Plus Silver...
HP 12C
gtabblt.gif Description gtabblt.gif Resetting the calculator using the keyboard gtabblt.gif Resetting to drain the capacitor gtabblt.gif Other solutions gtabseps.gif Description Sometimes a calculator will lock up or will not respond correctly. The calculator may require a reset for a variety of reasons. These resets will erase the memory on the calculator and restore the calculator’s defaults. For this reason, it is important to back up any critical data. Resetting the calculator using the keyboard The easiest reset is done from the keyboard. To reset the calculator, follow the procedures below in the order presented.
  1. Press ON to turn off the calculator.
  2. Press and hold [ - ] .
  3. Press and release ON .
  4. Release [ - ] .
  5. The screen will display “ Pr Error
  6. The calculator will reset to the default settings, and the memory will be erased.
If the above reset did not restore the calculator to normal, continue to the next section.
Sep 04, 2008 | HP 12c Calculator
Casio fx-300ES Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
