Question about GE JE1660 Microwave Oven
My microwave makes a humming noise and I'm starting to smell something burning. What do you think tha problem is?
    President:
  • 842 Answers
The article I just posted: http://www.fixya.com/support/t1790531-microwave_arcing_antenna_blade may well give you a solution
Posted on Mar 13, 2009
I have a maytag model mmv1164ws when you turn it on makes a buzzing and smells like something burning!
Something is burning, there are high voltage parts in a microwave oven and they wear out. You probably need a new diode. Part number WPW10492276 google it
Aug 30, 2016 | Maytag MMV1164WS Microwave Oven
Generic problem for all Kenmore Microwave
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it .. zaheer Islamabad
Dec 31, 2009 | Kenmore Microwave Ovens
Our Sharp microwave oven turns on, makes a loud humming noise, starts to smell like something is burning, but doesn't heat. Well, actually, we don't think it heats, we're too scared to let it run because...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} This can be caused by grease etc. inside the oven and on the wave guide which is the paper like thing in the oven. If you can remove it look for burnt areas which may can be scraped off or you may need to replace it. An appliance parts store usually has the material you can cut to fit you own.
Dec 10, 2009 | Sharp R-530ES Microwave Oven
Hey Thanks!! I tried to warm food in the microwave and the microwave started to make a strong humming noise, didn't warm the food and has an strong electrical burnt smell. -What's wrong?
The unit had a meltdown. Anytime you smell something thats not normal its alway an internal failure. You could send it out to be looked at but at the price to replace it your better of getting a new one.
Nov 27, 2009 | Microwave Ovens
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
Panasonic Microwave NN-C980-B buzzing noise but it still works.
All:
I have a 2003 Sears Ultra Wave microwave 721.63682300 with a similar problem. A few months ago it started giving off short buzzes when turned on. That stopped but then I noticed that everything took twice as long to heat up. After quite a bit of teardown&inspection I found a circuit break in the inverter board leading to ZD704 diode (pictured). I will now try to find a replacement diode to see if replacing will fix it. Thanks for your postings.
Feb 15, 2009 | Panasonic NN-C980 Convection/Microwave...
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Started making noise
It's probably the magnetron or high voltage transformer, but it may also be a failing high voltage diode.
Depending on the age of the unit, the magnetron may still be under a part warranty, but taking it apart would likely void that warranty.
If you think it might be under warranty, you should contact LG. For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
If you decide to check it further yourself, we have a similar model's service manual on our site:
http://www.microwavedisplay.com/mv1555st_sm.pdf
Bear in mind that the part numbers will not be the same for yours - you will have to call LG to get proper part numbers.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 26, 2008 | Goldstar MV-1501 Microwave Oven
GE JE1660 Microwave Oven Logo
234 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
