Question about Sharp MX-2300N Color Copier
Sharp mx-c311 remove paper from center tray... we have and it says put paper in center tray can not print
  • 47 Answers
SOURCE: SHARP MX-2300N
Someone has sent a print job from a computer to the copier with an odd paper size specified. Go to Job status, under "print" highlight the first job in the que and delete it. (if the job was sent more than once you will have to repeat. ) Check the document and print settings of the offending document.
Posted on Dec 07, 2008
  • 140 Answers
SOURCE: IN MX-M350N SHOWS "REMOVE PAPER FROM TOP TRAY" AND DOESN'T PRINT
You probably have a paper jam in the auto feed unit. Open the auto feed and check for bunched up paper and if you don't find any open the side doors and check for paper jams there. Let me know what you find.
Posted on Feb 13, 2009
tehnik_bdg
  • 91 Answers
SOURCE: Sharp printer copier MX 4501N, how to remove the
Pull the paper tray to the front, after it is stuck pull it up ward and front
Posted on Apr 16, 2009
tehnik_bdg
  • 91 Answers
SOURCE: sharp mx 3500 won't recognize custom paper
In the printing properties, on the paper select tab, change the paper tray from automatic to by pass tray
Posted on Jun 23, 2009
dwylie76
  • 80 Answers
SOURCE: Our Sharp MX C311 gives
sounds like your NIC card is bad, no network cable plugged in or the network port in the wall is not an active network port.
Posted on Nov 10, 2011
Bypass tray problem
What error does the machine display?
May 08, 2013 | Sharp Office Equipment & Supplies
Mx2300n try to print envelope from bypass tray but error says
Try putting the paper in the 2nd paper tray and then go to system settings then paper tray settings and change to paper for that drawer to envelope and maybe COM10. Then try to print on the envelopes.
Dec 11, 2011 | Sharp MX-2300N Color Copier
How do i print 6 3/4 return size envelopes on a sharp 2600n
You have to select the Manual Feed Tray by touching the picture of the copy machine on the LCD screen. That will then show you the paper trays. Touch the paper type soft key for the Bypass/Manual Feed Tray and then select envelope. then press ok a couple of times till you are back to the main screen. Put your envelopes face down on the Bypass/Manual Feed Tray. If you are printing from a computer do the same thing after you go to printing preference/properties.
Oct 20, 2011 | Sharp MX-2300N Color Copier
There is an error on the screen which says "remove paper from the paper tray" and there is no paper to be removed. What can we do?
G'day, I know the answer from much investigation. you see I had the same problem "Remove paper from center tray". This fault occurred after a weekly wipe down of all moving parts to prevent the print rollers from becoming "Sticky" (with residual toner). I could not work out this fault I read the above answer and spent at least 40 minutes pressing prox switches and messing around with tray setup, and nothing the fault still appeared. then I decided to read the manual, and... Guess what NOTHING on the specific "Remove paper from center tray", but what I did find is that the "Center tray is non other than the Output Tray, you know, The Spot where your new fresh printed paper comes from. If you get a torch or light and look inside you will see two leavers (one double leaver and one single leaver). The single middle leaver is your problem, it senses to see if the "center tray' is full so that it can stop printing to avoid a problem. this center leaver comes unattached, all you need to do is clip it back into its home position. Straightaway your problems will go away. Cheers McHaggerty
Aug 30, 2011 | Sharp MX-2300N Color Copier
i have a sharp m7001n that says to remove paper from center tray cant find there is not a finsher on it also says tray 1 and 2 is prohibited.can you help
Sep 20, 2010 | Sharp MX-2300N Color Copier
Jobs going to Sharp MX-C311, but printer not printing them
Worked with Sharp Support- client was using accounting and passcode was not set
Jan 20, 2010 | Sharp Office Equipment & Supplies
Sharp mx 3500 won't recognize custom paper
Jun 19, 2009 | Sharp MX-2700N Color Copier
Sharp MX-2300N Color Copier Logo
160 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
