Problem with emptying the clothes softner on a lg wm12336fd
The fabric softner isn't emptying from the draw on the washing machine despite being cleaned
zeusfaber
  • 247 Answers
SOURCE: Fabric conditioner still in draw after wash cycle
This is usually a matter of pulling the drawer right out (it is designed to let you do this) and taking it to bits (it's designed for this too). Most front-loaders have a bit of a design weakness in that the bit that gets blocked with conditioner isn't immediately obvious without a little bit of prior dismantling. Once you get the top off the drawer, you'll almost certainly find the siphon tube gummed up with old conditioner. Clean this up under a hot tap, then reassemble and all should be well. A.
Posted on Apr 25, 2007
  • 641 Answers
SOURCE: Maytag Washing Machine
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Sep 06, 2007
barkencoa
  • 3463 Answers
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch classix 1000 express fabric conditioner won't empty
Get a piece of stiff wire, and make a right angled bend at the end of it, then poke it in all the holes on the top of the soap drawer compartment, this should solve your prob.
Please rate my solution.,
Thanks.
Posted on Jul 16, 2009
  • 24 Answers
SOURCE: fabric conditioner drawer not emptying
take drawer out to clean. take it apart and clean top bottom back and front, sounds like theres a blockage stopping the conditioner from syphoning out'
Posted on Aug 05, 2009
My clothes are coming out dirty. dirt is settling on my clothes from the rinse.
Put a cup of vinegar in an empty washing machine fill with water and wash without clothing in it. Should sort the grime caused by fabric softner.
Feb 04, 2016 | Kenmore 24032\24036 Top Load Washer
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Not emptying conditioner compartment conditioner
This video will show you how to keep your soap draw clear and how to service the parts
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2011 | Hotpoint Aquarius WD63 Front Load...
Black on door seal and water filling fabric softner section in dr
hotpoint Aquarius
Please remember to subscribe to our YouTube channel for all appliance tutorials
Dec 20, 2009 | Washing Machines
The fabric softner dispenser is clogged. it fills
Pour really, really hot water into it and that should disperse the fabric softerner...then run the washer with NO clothes in it...good luck
Aug 11, 2009 | GE Washing Machines
Water being left in the dispensers when the washer cycle is done
Water in the fabric softner slot is normal, but for the detergent slot you have to clean out with a tooth brush if you can't get the tray out. If there is water there it is quite a serious block, which is affecting your wash.
Mar 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Fabric softner still in draw when wash finished
There is a blockage in the dispenser that is causing the prob.
Remove drawer from dispenser, and thoroughly clean every part of it, taking all the pieces out to do it.
To test it is working, put it back together, and before you put it back in, fill the conditioner compartment with water until it starts to overflow, turn water off, and the remaining water should continue to run out, until it is empty, if it does not , then it is still blocked.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Washing Machines
Water collecting in the fabric softner dispencer
you need to take out dispenser draw and clean out under tap
the softner dispenser syphons out and if channels are gluged up the dispenser will not empty
Mar 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Softner section won't fully drain....
Aug 14, 2007 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
