Question about Home Security
Ge wireless door chime manual for a 19216/st-66 - how to change the frequency code
How do I change the frequency code?
SOURCE: door chime code for GE model 1601S &1602S
Hi there. I think I have the same GE chime. It has a series of 4 dip switches on the bell (base) and also in the switch unit. Just make them the same. On mine for example, switch # 1,2 & 4 are up (on) and #3 is down (off). Any combination of 16 codes should work as long as both units are the same. Just as an aside, I had a problem with mine working intermittently, then mostly not at all. It was the actual pushbutton switch inside the button unit. Luckily, I replaced the micro-switch and it's working again. Also during cold wet weather, the 12v battery gets depleted faster than normal probably due to moisture inside the switch unit. I taped a piece of plastic from a sandwich bag over the switch unit to help keep water out.
I hope this helps.....
Posted on Dec 16, 2008
ButtFuzz
  • 463 Answers
SOURCE: dings sometimes with out pushing the button ??
I believe there are either dip switches (or old-fashioned "jumpers" in both the button (the 'transmitter') and the dinger (the receiver). See if this is the case, and that the dip switches (or jumpers) are in the same position in both units. Then, simply switch one of the dip switches (or jumpers) to another 'position' in both the button and the dinger. There ya go...
Posted on Mar 05, 2009
SOURCE: Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
Posted on Aug 31, 2009
  • 18 Answers
SOURCE: How can I change the frequency on my wireless
Not sure of this model so suggest you give them a call on
01925 712000
Posted on Nov 04, 2009
  • 1212 Answers
SOURCE: Friedland Evo Wireless Door Chime and Push Problem
While this is a little bit of a stab, if you replace the batteries in both units, do it at the same time, If the batteries are known good ones, simply take them both out and let the units sit for about 5 minutes before you put them back in. Make sure the battery contacts are clean and devoid of corrosion. Put them back together without pressing the button. I assume it is of the newer "self learning" style. In which case, hold the ringer button down until the chiime goes off.
If it is one of the optical greeters, there would be a setup switch position that allows you to focus/align the reflector for the greeter. Usually it keeps chiming until the alignment is correct whereupon it shuts off when things are right. Then you reset the switch to normal. If no switch for set up at all- just follow the same procedure until it stops. You can usually "eyeball" them pretty close without effort.
Posted on Dec 31, 2011
GE wireless door 19216/ST-66
They pick up signals from taxis and tow trucks. One some you can change the channels. Unfortunately the problem of 'wireless'.
Jan 29, 2018 | GE Home Security
My bell ring everytime my next door neighbor's bell ring & even the neighbor three doors down. What is up with that?
They're all set to seeing frequency you need to go into your owners manual and check how to change wireless frequency
May 12, 2014 | Heath Zenith SL-6144 Specialty Series,...
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
I have a ge wireless doorbell and I need to change the codes. there are 3 dip switch setting and 4 removable switches
The 3 dip switches set the different chime sounds. The 4 jumpers set the code....you will need to change the jumpers on the back of the receiver to match as well
Nov 26, 2009 | Desa International White Wireless Plug In...
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
Door chime code for GE model 1601S &1602S
Nov 22, 2008 | Home Security
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
1,321 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
