Question about Metrologic Instruments MS951 Handheld
Metrologic ms951 handheld with serial port not working
Got a new computer with windows 7. scanner worked on old computer. Is there software that needs to be installed on the new computer?
SOURCE: Metrologic Keyboard Wedge Barcode Scanner (MS5145)
I found a solution. The scanners needed to be reset to default. (via the manual) Thx anyway. Didn't know they could be configured for use without a kboard... That definately bit me once.
Posted on Aug 23, 2007
  • 3 Answers
SOURCE: Need driver software
hi first you need to know what the interface is then if its keyboard wedge programme for keyboard emulation. if its serial you will need some type of pos programme to run it in if its usb it should be plug and play hope this helps 2dornot2d
Posted on Sep 20, 2007
SOURCE: Can't even start Metrologic voyager 9520
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Posted on Nov 25, 2008
rdiodoro
  • 13 Answers
SOURCE: Connecting Problems with Metrologic MS9535 BT
hi
that you have cable usb?rs232?ps2?
You have the power adapter?
you have windows xp?
is not difficult
Posted on Dec 17, 2008
jackcity
  • 33 Answers
SOURCE: Trying to use Casio PCR-T2100 cash register & Metrologic scanner.
for the scanner, u need to program it to suit Casio Cash Register, eg: baud rate, parity , data bit & so on...other wise, the Cash Register cannot receive the signal from the scanner.
After program the scanner , please perform "flag clear" to the cash register.
Posted on Sep 13, 2009
What can a metrologic scanner model MS951 plug into?
no mac, Pcs only. Depending on the interface of your scanner it would plug into either a keyboard port with a y cable or a serial port
Apr 13, 2012 | Metrologic Instruments Metrologic MS 951...
My notebook computer only has USB plug and it does not has serial port plug (RS232). I bought a USB converter cable for the RS232 plug. The notebook computer reconciles the USB converter cable and not...
Tthe Capshare only works with XP or Windows 7 Ultimate which has a virtual XP inside it ( a retrofit for outdated software).. I will not work with VIsta.
Feb 13, 2011 | HP CapShare 920 Handheld Scanner
Hooked scanner up to new computer. Reads bar code
It sounds like you are connecting to a serial port and you are trying to scan into a program that needs keyboard data. Download the "Softwedge" program from the Metrologic website.
Mar 27, 2009 | Metrologic Instruments 9520 Voyager
Mar 27, 2009 | Metrologic Instruments MS9540 Voyager...
Voyager 5929 doesn't work with Vista
The problem isn't your scanner or Vista, it's your adapter. Power requirements and speed of data require special adapters. One I always recommend is Scan Technology's part # STI-PS2-USB. I've tested it with all Metrologic scanners and it hasn't failed yet.
Dec 30, 2008 | Metrologic Instruments Voyager MS9520...
MS9520 serial connected to the terminal - does not send keys to the terminal server
Ok this is an old questions, but I had a similar problem recently. I found that I had to install Softwedge on the Remote computer.
I was trying to use the scanner over remote desktop. Remote dektop needs to have serial communication enabled. The computer that you are connecting to via RDP needs to have softwedge installed.
Nov 07, 2008 | Metrologic Instruments 9520 Voyager
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
Sep 18, 2007 | Metrologic Instruments Orbit MS7120...
Metrologic Instruments MS951 Handheld Logo
35 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
