Question about Kenwood Audio Players & Recorders
Need a Kenwood KX-W6010 Dual Cassette Manual
I own (was given) a Kenwood KX-W6010 Dual Cassette Deck. I am looking for a users manual (none on Kenwood's site). Note that it is NOT a KXF-W6010.
Does anyone have a manual they would sell or scan?
  • 79 Answers
SOURCE: Kenwood Dual Cassette deck KX-97CW runs fast
Sometimes this is due to the tape not being pinched between the capstan and the rubber roller.
Make sure there is no slack in the tape when you put it in the deck. See if you can observe the tape going down over the capstan on the correct side.
If this isn't the problem, then the mechanism that engages the capstan roller may not to be working. In most cases, the rubber roller is mounted on the same mechanism that moves the record-play head against the tape. If this mechanism isn't moving, that would cause the problems you describe.
Posted on Mar 15, 2008
SOURCE: CT-W602R Dual Cassette Deck- door won't open
had same problem, just changed the belts and works like new.
Posted on Nov 18, 2008
  • 205 Answers
SOURCE: Need manual for a Denon Dr-M3 cassette deck
http://www.retrevo.com/support/Denon-DRM-555-manual/id/363ci856/t/2/ try this link
Posted on Oct 15, 2009
mark24354
  • 776 Answers
SOURCE: need instruction manual for denon drw-660 dual
http://www.user-manuals.com/advanced_search_result.php?keywords=denon+drw-660+&osCsid=11873a748fd5790e73fdb0587299c24e&x=10&y=14
$10
You may find what you are looking for in another manual. Denon has some manuals on their website www.denon.com. Look for SUPPORT tab, then service manual. On the bottom of that page, they have info for some discontinued models. Read them and you may have the answer to your questions
Posted on Mar 15, 2010
djtatty
  • 417 Answers
SOURCE: Need to find user manual.
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Posted on Mar 01, 2011
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
KENWOOD KX56W/CW
I have a KX-56W. I can get the user manual for you if you still need it
Jul 02, 2013 | Audio Players & Recorders
Looking for schematic for Kenwood KX-55 stereo cassette tape deck
These dual cassette deck are rarely worth he effort to put repair time into. I checked Hi Fi Engine and they did not have anything. Is it worth a $100 repair bill? if not then look for a good solid single deck.
Mar 31, 2013 | Audio Players & Recorders
I have a kx-w4050 dual kenwood tape deck niether side will play hear click and counter moves one then another click. Is there a way to fix this?
Yes, the belts need to be check and idlers or whatever drive mechanism that is used in that system. Dual deck units are among the most unreliable units there are and a reason I tell people for the last 30 years not to buy those things. Almost most of the time they are not worth fixing due to their poor performance at the end. These are facts not just opinion.
Jan 14, 2013 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood tuner/graphic equalizer c-h6
sound output section trouble.can you remoove and shall we start rectifing the problem.
nuwan
Dec 04, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
309 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
