Question about Binks 2100-2800-7 Conventional Spray Gun
Spray gun spits finish - Binks 2100-2800-7 Conventional Spray Gun
Spitting
most paint spray guns require the paint to be thinned this may be the cause of the spitting
Apr 15, 2014 | DeVilbiss Jga-510 Paint Gun Sprayer Item...
Paint gun not shooting correctly
Seeing how you have really stated what the problem is (spitting, clogged, won't shut off, fan pattern wont adjust Etc) and there could be several different things wrong- lets go over some basic spraying A B C'S- always strain the paint through a strainer bag or cone this will remove any debri that might clog the tip, *THINNING when you spray or atomize paint it should always be thinned it will actually cover much better if you thin it with the appropriate solvent water for latex thinner for oil base you want to stay in the 15% range alittle bit more on hot days. The shape of the spray that comes out of the tip is called "fan pattern" or "tip fan" "fan size" you can adjust the fan pattern from 9:00 - 3::00 or sideways to straight up and down or to a small circle this is done by moving the "tip housing retainer" keep a piece of cardboard to practice and see. IMPORTANT:When you have finished spraying you need to clean the entire gun by running the right solvent through the gun untill nothing but clean solvent is coming out dissemble the gun remove and clean needle and needle housing this is not very complicated and is paramount to maintaining any spray equipment for sure the gun....
Perry Tradesman
Dec 29, 2013 | GRACO INC 3900 Handheld Paint Sprayer...
I'm having a problem with my finish line flg 3.. I'm getting air bubbles blowing back up into the cup of my gun causing the paint to spit out when I try to spray.. Is there any reason this would be...
Make sure that the vents on the gun are clean and if the problem is still present then you have a problem with wear on the bushing or the needles. Air is blowing back into the cup before the needle is opening enough. So this could be a pressure, timing or wear issue.
Nov 25, 2013 | Air Tools & Compressors
440i wont stop spraying
Either your gun is dirty and the valve spring can't close the tip valve properly or the seat it pushes against is damaged. First try cleaning the gun very throughly. Take it apart and get everything out of the gun that doesn't belong there. If it still does the same thing you can buy a repair kits for the paint guns but they're usually expensive and you're almost always better off replacing the gun.
Sep 29, 2012 | Titan 440I Spray Guns
I am in Davao, Philippines and just bought this spray gun. I have no experience of using spray guns and was surprised to find there is no manual. Not even basic info like which adjuster is for fluid and...
Im a professinal spray painted. Although i now what you have there are a lot of variblys this is called a conventional system. Is made for light meteral spraying on metals or fine finish objects. Paint quilty and thinning and proper air control feed and volume are the most critical as well as the envirment that you are working in do to the extened time it takes the meterial to set up and the number of coats to achive the mil thickness required for the product to proform at its specified levels. Looking at your gun if the picture is correct the upper control knob is the spray pattern control and the second knob is the paint or fulid control the amount of paint that comes out he tip that is also controlable but olny from vertical to horizontal pattern it should come out in a cone shape. And what you realy need hear is a regulator between the regulator at the compressor and the air supply at the air hook up on the gun and also a water trap in line before that so condensation drops woun't spit out the tip and pock mark the finish. Idon't know what you want to use this mechine for but it is a vary complex opperation and you had better do your homework if there is liabilty involved with what you are doing. good luck
Jan 02, 2011 | Buffalo Tools 1 Quart Capacity Air Paint...
Why does my gun keep spitting
Spitting is usually caused by not filtering the paint through a strainer (made for the purpose by the paint manufacturer). The paint debris blocks the paint for just a moment, then spits it out. Easy fix!
Jun 09, 2010 | Wagner GX10 Airless Spray Gun
PAINT GUN SPITS PAINT AFTER ABOUT 10 MINUTES OF USE
Are you straining the paint through cheese cloth or some other type of strainer ? Trash in the paint building up around the tip could cause it, straining will eliminate that. The return spring, or the grommets depending on what type of gun your using could be wore out keeping the needle from seating closed all the way. Is it when you stop spraying or during. May need to change the pressure setting or tip size for the material you are spraying, again, depends entirely on your specific situation as to what could be causing the problem. But these are things you can try. The paint store would probably be able to point you in the right direction if it comes down to changing tips. Might be worth a call to save yourself more aggravation. hmmm,, goes to show how observant I am,, sanchezauto,, are you painting cars,, with a conventional cup gun ? All of any of the above could apply. And if your painting cars you sure don't want a spitting gun messing you up. (-8
Nov 19, 2008 | Air Tools & Compressors
Vaper primer gun has intermittent air supply
Does it come with instructions? The material thickness is VERY IMPORTANT when choozing the proper nozzle.
Nov 17, 2008 | Northern Tool Vaper 2.0mm Hvlp Spray Gun...
Binks 2100-2800-7 Conventional Spray Gun Logo
27 people viewed this question
Top Binks Air Tools & Compressors Experts
JOHN LAPIER
john h
russ davis
Are you a Binks Air Tool and Compressor Expert? Answer questions, earn points and help others
