Question about Hitachi 43FDX20B 43" Rear Projection Television
Hitachi 43FDX20B 43 in. Rear Projection Television won't power on.
TV was playing and suddenly it went black and the red light on the power button began to flash on and off. Waited 30 seconds and tried to power it back on still the same flashing red light with no power to set. Unplugged the set and wait again 30 seconds and re plugged it and tried to power it back on and still the flashing red lights on the power button. Anyone know what the problem is??
    Genius:
  • Hitachi Master
  • 2,432 Answers
Check for a bad lamp then make sure the fan is working.
Posted on Apr 19, 2013
SOURCE: flashing power light
you need 4 caps in you dm module they are 1000 mf @35volts
Posted on May 25, 2007
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
video-tek
  • 150 Answers
SOURCE: Hitachi 43FDX20B 43 in. Rear Projection Television magic focus
Hi, replace the convergence IC`s and any fried resistors and chemical fuses (if any), do not push magic focus anymore it will not correct the prroblem and it will evenntually corrupt the DCU and cause you more problems (and of course more money), questions? ask awayy, video-tek
Posted on Feb 08, 2009
SD Tech
  • 14553 Answers
SOURCE: Tv will not turn on
This is shutdown on this set---inside the set on the power board and or the main board should be several LED's(1 is red and the rest are green) look in side with the set turned off and when the set is turned on do all the green leds light? if they light for a moment and then go out look for any of them that go out first---It could also be a short on the supply to the convergence circuit---only way to know that is to unsolder the 2 convergence IC's and see if set comes on--it can also be a vertical or deflection problem--this set is very well protected and will shut down for a number of reasons---if you have questions or need more information contact me--etower.766@netzero.net
Posted on Aug 09, 2009
My little red light in front is flashing, what can i do if anything?
if the lamp indicator is flashing that was mean you have to check the lamp inside if worn out which need to replace.if the power indicator is blinking you must look for the power supply board which failed check for any burnt parts.
Sep 05, 2012 | Hitachi 43FDX20B 43" Rear Projection...
The power light keeps flashing red and green the tv wont show picture or sound
Usually this is a case of bad bulb. While having this replaced have all fans cleaned of dust including projector assembly.
Jul 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
The red light on front of tv is on but tv itself (picture), sound
Check all the picture bulbs works.
This is a plasma tv right?
U have it along time right?
Aug 13, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Red light on front, no audio,video, have unpluged and left unplugged for days , plug it back in and get the same thing
the red light is on because part of the power supply is still alive(usually +5v source), but there could be a problem after the ps that might be causing the tv to go into shut down. that might be why there is nothing happening when power is pressed.
Aug 07, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43FDX20B, watching tv, screen went blank, no picture, no sound turn off then back on power light on but the same nothing
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Jul 24, 2009 | Hitachi 43FDX20B 43" Rear Projection...
WANT 2 KNOW 43FDX20B HITACHI TV IC NUMBER NAD PART NO
You can find OEM IC's for this model (43FDX20B) from a major Hitachi parts distributor on the link below:
Hitachi 43FDX20B Replacement Part IC
If you contact them and provide the generic number or location number of the IC, they should be able to provided you with the needed parts.
Apr 02, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43fdx20b too much red, green is off
If your Hitachi TV was manufactured 15 years ago, it most likely is worn out by now.
Jun 12, 2017 | Hitachi 43FDX20B 43" Rear Projection...
Flashing power light
May 23, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi
if you can hit it and it does something it's telling me you have a loose connection. or cold solder joint.
Apr 28, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX20B 43" Rear Projection Television Logo
145 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
