Question about Matsushita DD73C14GAU6 1/4 HP R134 Compressor 115V/6Compressor
Refrigerator defrozes but it takes to long to start again the compressor causing the ice cubes to melt
Why is Ice maker for rf26xaewp making ice but it is melting ice to form large cubes and then forcing tray out of lock position
there is usualy a sensor that tells when the ice is ready
and then it melts a little and then releases the ice easy from the tray
perhaps its all jammed up
stop it working for a day or two and give it a good clean with spray water mixed with 5% bleach then plain water
and also check there isnt anything obvious with the tray section mecha wise
i think its got confused somehow
ive even seen ice maker issues caused by poor evaporator tubes from the chiller to the the tray on top of the compressor
so clean the v shaped section at the back and its center tube fully and add some salt
to clean the freezer one you need to fully defrost for a few days and take the back panel off the freezer unit and clean the pipes again salt it
Dec 08, 2014 | Samsung RF26XAEWP 26 cu. ft. French Door...
Ice forms as large block not in cubes
Defrost thermostat is bad. Defrost element is staying on for too long raising up temperature causing ice to melt.
Mar 26, 2014 | Fisher and Paykel Active Smart E522B...
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
Symptoms: Ice cubes melt, drip then refreeze causing
are you having any cooling problems? take a look at your ice cream, if you have any. does it look like it has melted and refrozen? if so, you have a cooling problem, and that is causing ice to melt, then refreeze. if you have no cooling problems, then you may have a faulty water valve solenoid, or even a faulty icemaker.
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice in my ice maker bucket is melting and refreezing into a solid mass. I just looked at a recently made cube and it still has liquid in the center.
Yours has a 215846602 Defrost Timer, Located inside the fresh food compartment. I believe that it's sticking in defrost and you possibly need a new defrost timer.
Here is a photo location of the timer # 23 is the timer. I want you to turn the timer until the refrigerator compressor stops. Time it for about 25 minutes and the refrigerator should restart. If not then it's sticking in defrost so again turn clockwise slowly until the compressor restarts. That is possibly what is causing the melting and refreezing. Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
Aug 19, 2009 | Frigidaire FRT18S6AQ Top Freezer...
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Ice Tray Freezes & ice builds up around internal workings of ice cube holder
Check and make sure you door seal is tight. Take a dollar bill and place it between the door jam and gasket, close the door and then pull the bill slowly out. It should be rather tight all the way around. So you will have to do several checks all the way around the door. If you have a bad spot call and have them either replace the gasket or adjust the door.The other thing you can do (I have found most if not all manufacturers require this) empty your ice maker once a week. The problem comes from your refer being a self defrost. There is a heater coil that gets as hot as a range element to defrost the evap coil. It is the defrost cycle that causes the ice to melt down a bit. And the defrost cycles every 12 to 24 hours causing the cubes on top to melt down some. So as your bucket fills whatever was on top melts a bit and by the time you are ready to use several layers may be melted causing them to stick together.
Jun 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Apr 21, 2007 | KitchenAid KSRS25ILSS Side by Side...
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
Matsushita DD73C14GAU6 1/4 HP R134 Compressor 115V/6Compressor Logo
13 people viewed this question
Top Matsushita Heating & Cooling Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Marat Brikov
Are you a Matsushita Heating and Cooling Expert? Answer questions, earn points and help others
