Question about Mitel Superset 4025 Corded Phone (mitsup4025)
Mitel superset 4025 flashing light won't go off
leftypicker
  • 4 Answers
SOURCE: Changing time on my Mitel Superset 4025
The only way to change the time on your individual phone is to change the time on the entire phone system.
Posted on Mar 10, 2008
  • 15 Answers
SOURCE: Checking Voicemail Remotely.
You will need to call in to the Voice Mail hub extension directly, then press * to identify yourself as a user (on some systems you may need to press # or press * twice). The system will ask for your extension and password and you will be granted access. Your system administrator can inform you of which extension is the VM hub on your system.
This is what Christ at Mitel told me. I'm still trying to find out our hub extension number.
Posted on Mar 05, 2009
ynotphone
  • 192 Answers
SOURCE: Want to divert calls from one Mitel Superset 4025 to another.
Under the Blue Superkey, there is an option for Call Forwarding.
Go to the call forwarding and put in the extension that you want to forward to, and then enable it.
To disable the call forwarding, you have to go back into the Blue Superkey and disable the call forwarding from there.
It's either that, or your system programmer may have given you a call forwarding button on the set to enable and disable easier.
Posted on Apr 18, 2009
SOURCE: I have a Mitel Superset Phone 4025 and the display screen says Messages Phonebook and there are no messages.
That just means there is a call me back message. If you push messages and clear the ones you have then the light will stop blinking.
Posted on Jun 22, 2009
SOURCE: How do you set up the caller Id on Mitel Superset
Here is the manual it is all explained in it. Link below. edocs.mitel.com/UG/EN/2ICP_4025_UG_R2_EN.pdf
Posted on Mar 10, 2010
Get display screen & soft key screen to light up on mitel 2000-superset 4025
Some 4025 supersets have back lit displays and some don't you may have the model that does not light.
Oct 07, 2014 | Mitel Lands Phones
Mitel superset 4025 mute
The "MUTE" button on the Mitel is the microphone "MIC" button.
May 26, 2014 | Mitel Superset 4025 Corded Phone...
My message indicator light does not blink when I have a voicemail on my Mitel SuperSet 4025. What do I do to make it blink when I have a mesage?
This is a feature code set by the voicemail system. If the code isn't set properly in the voicemail server, then the lamp won't light. Here's a few troubleshooting steps for you to follow...
Are others having the trouble? If so, then it's a system wide problem and you should contact your vendor to have it looked at.
If it is isolated to your phone... swap phones with another user with a 4025.... leave a message in your mailbox... did it light the lamp? If so, leave a message for the other user and see if it lights the lamp on your phone at their desk... did it light the lamp? If NOT, then you've got a bad phone and you should contact your vendor to have the set replaced/repaired.
sincerely,
Mark
Apr 29, 2011 | Mitel Superset 4025 Corded Phone...
I have a Mitel Superset 4025. The "message" button was somehow reprogrammed so that pushing it now calls the operator, I can access my VM using "8" but the message waiting light is...
it's because the operator set a message to your phone. You need to leave the handset on the cradle and push the message button. Read the display and follow the prompts. You should be able to clear the message.
Apr 27, 2011 | Mitel Superset 4025 Corded Phone...
I bought several used mitel superset 4025 phones. When I try to plug them in (we have two phone lines in one jack), the display flashes "waiting for sync" and the lights on the phone flash (in succession...
the Superset 4025 is a digital set that is intended to work with a Mitel telephone system. The port must be programmed and connected to a jack to allow the phone to work. The phone is not intended to be used as a home telephone.
Aug 18, 2010 | Mitel Superset 4025 Corded Phone...
Caller id displaying DID's
It sounds coincidental. You should contact your vendor as I think there is something in the programming that's changed. Either in the set's class of service or in the trunks class of service.
Jun 07, 2010 | Mitel Superset 4025 Corded Phone...
How do you set up the caller Id on Mitel Superset 4025
Mar 10, 2010 | Mitel Superset 4025 Corded Phone...
Jun 03, 2009 | Mitel Superset 4025 Corded Phone...
How do I set the time on an mitel 4150 and 4025 phone
Need to log into phone system or if the 4150 is a sub att. you go through the softkeys.
May 16, 2009 | Mitel Superset 4150 Phone
Want to divert calls from a Mitel Superset 4025.
Under the Blue Superkey, you can find a Call Forward prompt, enter the extension that you want to transfer your calls to and enable it.
To shut the call forwarding off, go back into the Blue Superkey and in Call Forwarding,t here is a disable call fording option
Mar 04, 2009 | Mitel Superset 4025 Corded Phone...
Mitel Superset 4025 Corded Phone (mitsup4025) Logo
44 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
