Question about NEC Electra Elite DTU 16D-2 Corded Phone
How to change time on NEC Electra Elite IPK? I
How to change time on NEC Electra Elite IPK? I was told " * Feature 9 # " but that doesn't change the time.
  • Anonymous Mar 21, 2014
    hot to change vm password on electra elite
You have to be on the root phone or "first phone".
To check various phones -Hit {feature} 4.
Should display 100= TEL 01. Once on the first phone then use {feature} 9 #.
Time will flash at top of display and can be adjusted.
If you are not on the first phone you will get error at the top of the display. Leave the hand set on the hook.
Posted on Apr 01, 2009
Try leaving the handset down and then pressing the Feature 9#
Posted on Mar 19, 2009
Dtu 16d ringer is off at other stations. I need to get the phone to ring on the other stations.
Hello, That would be a system ring group programming feature. It would depend on the type of phone system you have. NEC Elite 192, Elite IPK, Elite IPK 2. There are different platforms and this would determine how to program it.
Mar 04, 2015 | NEC Electra Elite DTU 16D-2 Corded Phone
How do i make the nec electra professional phone not ring
I think you have change its internal setting so reset your phone again so its again setup your phone and your problem has been removed like phone ring.
Nec sv8100 IPK DTerm phones Inlinecom
Aug 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
How to change from lunch to day mode
These phones work on about 8 NEC systems, but for a PRO II, an Elite, and an IPK, the standard code is Feature,80, Feature from one of the two main reception extensions. Don't know the code for a 2000, 8100, or IPK II.
Jul 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
How do i turn off the Night Mode
From one of the 2 main reception phones, press Feature 80 Feature , on a ProII, an Elite, and an IPK. For the other systems that use this phone you're best off finding the phone that has a night button assigned.
Jul 02, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
NEED TO CHANGE CLOCK TIME
On an Elite, IPK or Pro II, from one of the 2 main phones it's Feature,9,#, then enter hour, minutes, then seconds, then Feature to write and exit.
Mar 28, 2014 | NEC Lands Phones
What steps do I take to change the time on my NEC DTERM 80 phone system? I have already tried the Feature+9+# as well as the Recall+728 but those do not work. The first gives me an error message.
  • 1 Press the "Feature" key on the phone system's main terminal. This is one of the Dedicated Feature keys and is located at the bottom left hand corner of the keypad.
  • 2 Dial 9# to enter the clock setting menu.
  • 3 Enter the hours and minutes using the key pad. For example, if it is 12:15, you would press "1," "2," "1," and "5."
  • 4 Press the "Recall" key on the bottom left hand side of the phone key pad to toggle between AM and PM.
  • 5 Press the "Feature" key to exit the system.
NEC Electra Elite IPK II
  • 1 Press the "Speaker" key located at the bottom left of the phone key pad.
  • 2 Dial "728" to enter the phone's clock menu.
  • 3 Dial the hour using two digits. Use military time for any time in the afternoon. For example, 1:00 AM would be "01," but 1:00 PM would be "13."
  • 4 Type the minutes using two digits ranging from "00" to "59."
  • 5 Press the "Speaker" button to set the time
Read more: How to Change the Time on an NEC Phone ' eHow.com http://www.ehow.com/how_7338757_change-time-nec-phone.html#ixzz1XUGjOOet
Sep 09, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Dtr 32 d2 how do you change time?
First we need to know what type of system you have.
NEC 48, 192 or IPK 1
From port 1
Find port 1 by pressing feature 4 at each location until you find the one that states "Tel 01". Usually it is the lowest extension #.
Dial "Feature, 9, #" Enter the hour and minute. Make sure to have a watch handy so that you can sync it to the second. A good way to do this is by scrolling to the left and right for a bit so that it does not time out on you.
# - Should move to the right
Conf- Should move to the left (if not then Recall)
It does not state it in the attendant guide which way each option moves you. You can find the manual at the link below:
Elite IPK Attendant User Guide R1
The information is under Clock/Calendar Setting.
Nov 16, 2009 | NEC Lands Phones
Cant change time on nec etw phone
Try this:
NEC Electra Telephone System
Changing the time on a Electra Elite & Professional system must be done from the "main" or primary phone. It is usually extension # 100. 1.- Press "FEATURE" 2.- Dial "9#" 3.- Enter hour and minute 4.- Press "RECALL" to change AM/PM setting 5.- Press "HOLD" to change the calendar setting 6.- Press "RECALL" to change the day of week 7.- Dial "#" to move the cursor to day of month field 8.- Enter day of month 9.- Press "RECALL" to select month 10.- Dial "#"to move the cursor to year field 11.- Enter last 2 digits of year 12.- Press "FEATURE"
Carl
Nov 06, 2009 | NEC Electra Professional ETW-16DC-2
Changing amount of rings when going to voicemail
The call forwarding was turned off. To turn on, press speaker, enter 793, press 1(for set), press extention number, and enter 300. If you have call forwarding on and are looking for more rings, do the above steps except press 2 (for clear).
Nov 19, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
How do I change the time on the NEC Electra Elite IPK
  • From the programming extension (usually 100), with the phone idle and handset in the cradle, press the FEATURE button
  • Press 9 #
  • Enter the hour (01-12) and minute (00-59)
  • Press the Recall Key to change the AM/PM Setting
  • Press the Hold Key and continue if you want to change the calendar setting.
  • Press SPKR or hang up. The correct time should display
  • You must change the time from a phone with administration priveleges. This is usually going to be the main phone, extension 100 or 101. That phone must have an LCD display to make these changes.
    May 12, 2008 | Lands Phones
    NEC Electra Elite DTU 16D-2 Corded Phone Logo
    3,227 people viewed this question
    Top NEC Lands Phones Experts
    Brian LaDuca
    Oloyede Monsuru
    Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
