Question about Rowenta RH855201 - Air Force Vacuum cleaner - metallic plum ROWE
Finding spare parts for RH8552
I need a sweep drive belt
Brush wheel not spinning
it can be belt or clutch failed. put the vac on its side and on the bottom there will be either two push clips or 2 screws remove them or push them and pull the bottom off. then when this is off you will see were the belt is for the spinning brush. if the belt is still on then the clutch has gone in the motor if the belt has gone take out the broken part and get a new belt, fitting new belt you need to remove the spinning brush it is either clipped in or slotted in , clipped is push the clips out to the side and lift the brush out, slotted it will just pull out. clean out the brush before putting back in also check the brushes bearing to make sure it moves easy as a failed bearing do to carpet string etc can burn the belt, any belt that has been burnt in this way should be removed and changed as it will damage the hover if still used after this part has been cleaned replace all parts and then turn on dont and it pluged in mains while you are doing this and dont use until it has all been fitted back..
Mar 26, 2014 | Kenmore Intuition Upright Bagged Vacuum...
Tip
Ionic Breeze parts and repair
Hi.
Parts for this unit, including the filter are not on sale anymore, as all Ionic Breezemodels had been retired from commerce because of health and safetyconcerns.
No company will manufacture or distribute parts for this kind of Air Purifier. The units had been retired from commerce.
Sharper Image had been closed down because of the concerns linked to ionic breezer purifier.
Spare parts are not manufactured or distributed anymore.
Ionic Breeze Suit Drives Sharper Image into Bankruptcy.
Sharper Image Closing All Stores
Someonepurchased SI name and reopened the company. The company is distributing new lines of small appliances, but they do not manufactureor provide support for their original appliances.
SI successfully distribute and manufacture only new products that are not linked to any health concern.
Regarding your old air purifier, theonly way to find a replacement filter or parts is by finding the same model on Ebayfor spares....If I was in your shoes I would better get rid of your oldSharper Image , and buy a different kind of air purifier.
Regards.
Ginko.
on Jul 14, 2010 | Sharper Image Ionic Breeze GP SI730 Air...
Tip
Snow throwers
Just returned from the parts store, they had sold out of drive belts for the auger drive on snow throwers... figured I could help out here;
Wet snow is heavy, duh right? Before you run your snow thrower disconnect the spark plug, for safety. Check the chute, and sand any loose paint rust etc. you want a smooth chute.. paint if needed, let dry 24 hours before use, spray with silicon lube spray, this will loessen the stress on your auger belt and hopefully keep your machine running all season. Good luck!
on Feb 28, 2010 | Air Purifiers
The little dangling feet of my ionic breeze s1637
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
Dec 04, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
A spring leg (at the bottom of the grid) broke. The spring is still intact. Is the leg replacable or should I buy a new grid or unit?
Jul 25, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Filter for sharper image ionic breeze model s1730
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station.
Jun 22, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Broken Wire inside unit. Looking to have it repaired or purchase part.
You're probably screwed....
May 21, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Broken pin on air cleaner
Apr 23, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Air filter lid latch broke
Mar 30, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Fan replacement for Living Air Classic Purification System
Since I'm forbidden to offer you one of my spares (per Fixya's terms & conditions), I'd go on the web and search for an EcoQuest dealer in your area - - they can get spare parts from the manufacturer.
If I can be of further assistance, or if you have questions, please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Mar 22, 2008 | Air Purifiers
Rowenta RH855201 - Air Force Vacuum cleaner - metallic plum ROWE Logo
59 people viewed this question
Top Rowenta Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Rowenta Air Purifier Expert? Answer questions, earn points and help others
