Question about Buffalo Technology Buffalo MiniStation HD-PCT500U2/B 500 GB External USB - Black Hard Drive
How to unlock my buffalo ministation IN MAC - Buffalo Technology Buffalo MiniStation HD-PCT500U2/B 500 GB External USB - Black Hard Drive
  • 88 Answers
SOURCE: buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
Posted on Jan 11, 2009
SOURCE: cannot access data in my buffalo ministation orange light showing
Try accessing it in another USB port or computer. If still not, it may unfortunately be damaged. You may be able to get it replaced under warranty.
Posted on Jul 07, 2009
  • 4 Answers
SOURCE: apparently i need to reboot my BUFFALO &
Apparently -- if you don't know how to reboot -- you should perhaps ask some computer wizard among your friends for advice.
You don't reboot a hard drive (or any other device), you reboot THE COMPUTER. Which means you shut it down and restart it. During the startup process (which is synonymous to "booting") the computer checks all its internal interfaces and external sockets, takes an inventory of all devices and checks if they work properly.
Posted on Sep 24, 2009
bob_computer
  • 3153 Answers
SOURCE: xp cannot install this hardware. Buffalo
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Testimonial: "very helpful advice and correct also. I had changed the usb lead and it cured the problem."
  • 10406 Answers
SOURCE: my usb external Buffalo ministation
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
My hard drive is not recognized in my mac. The light is blue, neve turns to green
Have you tried to connect the drive to a different computer? You can also try to open Disk Utility (use spotlight search to find it). My guess is it doesn't show up there which means there is a problem with the Buffalo device. The disk is most likely fine, just the Buffalo casing needs to be replaced.
Apr 23, 2014 | Buffalo Technology Buffalo 1TB MiniStation...
Formatting buffalo ministation stealth for mac
Probably the software could not recognize or support the disk type/model
Dec 18, 2013 | Buffalo Technology 1tb Ministation Stealth...
Error code10 device refuse to start
PC or mac
try other PC?
try all direct connected, to PC , USB ports.
does the light glow red/green or blue? LED? if not , it has no power.
or is dead.
this slow drive gets its power from the USB port.
and is weak power and problematic , across all platforms.
the horses mouth
http://en.faq.buffalo-global.com/app/answers/detail/a_id/11884/p/1492,1493
Sep 29, 2013 | Buffalo Technology Buffalo 1TB MiniStation...
How to format buffalo ministation hdd in mac
Watch this video, select FAT file system if you want to use the drive in MAC and Windows
Feb 02, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
How to format hard drive into mac and window both
Watch video, make sure you select the FAT file system so that Mac and Windows can see and use the drive.
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
Error message if trying to save files larger than about 4GB.
The Buffalo Ministation hard drive comes with a default FAT32 file system. This file system is used for compatibility with Windows, MAC OS X, LINUX, etc. The file system does not allow files to exceed 4GB. To save larger files, the disc must be reformatted. For Windows, it should be reformatted to NTFS.
Jan 06, 2010 | Computers & Internet
Buffalo Technology Buffalo MiniStation HD-PCT500U2/B 500 GB External USB - Black Hard Drive Logo
37 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Ali Reza
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
