Question about Camping, Backpacking & Hiking
Charger for 5348 700 coleman lantern - Camping, Backpacking & Hiking
3 Suggested Answers
joboo1
  • 257 Answers
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Posted on Mar 16, 2009
SOURCE: I have a dual fuel,
Make sure that the vapourised fuel is coming through the mantle before lighting up. You should hear a hissing sound when the flame adjusting lever is turned to high. If not it is possible that the generator is clogged up and that vapourised fuel is not getting through to the mantle. So when you light up you are essentially just burning the mantle. If the generator is knackered it will need to be replaced. One way to check it to remove the generator, primed the tank and turn the valve on. If fuel spurts out when the generator is removed (DON'T LIGHT IT U)P THOUGH) but there is no hissing sound when the generator is intact then it is a sure sign that the generator is clogged up. In the UK a replacement generator should set you back £10-15. Hope this helps, Bandit
Posted on May 25, 2011
Need to change battery in my 4345 lantern
If you are talking about the Coleman 4345 lantern it is rechargeable using one of the chargers (mains or car) stored in the base. Are you saying it won't recharge?
Mar 30, 2017 | Camping, Backpacking & Hiking
Why doesn't lantern turn on when not plugged in?
I have a rechargeable spotlight and the directions specifically say not to turn it on while connected to the charger.
Mar 10, 2016 | Coleman Cpx 6 Rechargeable Power Cartridge...
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
In the Coleman 5312 Retro Series Lamp is it supposed to work off the mains charger even if the battery will not charge. Battery is confirmed dead but lamp will not work on mains nor on 12v car lead. Don't...
Brentonb, In the event that you don't get a direct answer (which is likely, since this is a pretty obscure question) I suggest you troubleshoot it this way. Remove the bad battery. Use the charging device that came with the lantern and wire it temporarily to the device in place of the battery. This will supply the correct voltage, but takes the possibly shorted battery out of the circuit. If you are certain you have the polarity correct and you know that the charger works, then you have your answer. good luck.
Dec 03, 2010 | Coleman Retro Rechargeable Battery Powered...
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Coleman lantern/fan/radio won't take a charge any more.
Yes there is, you can check out http://www.batteryinternational.com/lantern-battery.html to find a replacement, or call 1-877-28-BATTERY if you're having difficulty finding the battery you need. Hope that helps.
Jun 14, 2009 | Coleman Lantern Fan Radio (841.321) AM/FM
Coleman lanterns as collectibles
Coleman Collectors Guide 1903-1954.
Tucker & Ebebdorf
ISBN 0-9651407-0-9
This is an excellent reference with lots of pictures etc., it does not give the prices, however.
You can check Ebay for completed prices if you need an idea of value.
I have not found a book yet with accurate values on Coleman lanterns.
Apr 21, 2009 | Coleman Sport & Outdoor - Others
Hi With the rechargeable lanterns that charge by electric or car charger what do you put the lantern on to charge turn it off or put it on on or dc?
You connect the charger to the lamp and plug the charger into an AC outlet. Having the lamp on will increase charge time. The charger does not appear to accept feedback from the battery so it depends on you to disconnect it when charge is complete.
Jan 28, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Camping, Backpacking & Hiking Logo
66 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
weirdtop
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
