Question about Sewing Machines
Dressmaker Deluxe Zigzag sw-2000
Zigzag stitch setting
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
vash4me
  • 5 Answers
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Posted on Jan 13, 2009
RickE1
  • 202 Answers
SOURCE: how do i use the zigzag stitch on my bernina 830
Hi, open the top cover and if you watch what goes on inside from the top when you move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
Posted on Feb 07, 2009
SOURCE: Dressmaker S-2402 Instruction Manual
This is the threading diagram.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Dressmaker_Sewing_Machine_Threading/dressmaker_2402_threading_diagram.htm
Posted on Jul 01, 2009
Maggie_B
  • 3 Answers
SOURCE: Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
Posted on Oct 31, 2009
My dressmaker 7000 won't Change from straight stitch to zigzag the knob keeps going back to zero
sound like the machine may need to be serviced, to find out if there is a problem with the knob, see if there is a loose connection
Mar 22, 2016 | Sewing Machines
Where can I download a free manual for a Dressmaker Deluxe Zig Zag sewing machine SWA 2000
Try searching the internet for:
Manufacturer + Model + the word "Manual"
Perhaps this will help:
Dressmaker 2000 Sewing Machine Threading Diagram
Dec 19, 2015 | Sewing Machines
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
1249380 kenmore sewing machine
Depends on what stitch you intend to use. I do a lot of mending with a three step zigzag set to maximum width and minimum length -- see: http://www.picturetrail.com/sfx/album/view/24395076 A wide, short zigzag stitch is another popular choice, as is a straight stitch worked back and forth over the area: http://www.running-w-scissors.com/2014/01/tutorial-patch-mend.html
If you're just mending a seam that's come unstitched, a straight stitch or zigzag stitch similar to what's already in the seam is what you're looking for.
Feb 05, 2014 | Kenmore Sewing Machines
Not stitch zigzag
Have you tried a needle change? It could be blunt or the wrong size. Have you cleaned under the needle plate as the ridges get full of lint there. A toothpick will clean them out.
Nov 22, 2013 | Singer 1120 Mechanical Sewing Machine
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Dressmaker zig zag deluxe s3000 doesnt pick up bobbin thread
it's possible that a gear is broken or worn a sewing machine shop can tell you exactly
Feb 20, 2012 | Sewing Machines
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
42 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
