Question about Refrigerators
Why freezer not working...ice is melting - Refrigerators
    New Friend:
  • 7 Answers
Can you hear the fan running in the freezer when you have to freezer door open? If not the fan that blows the cold air over the cooling coils is either broken, or the fan is frozen in ice. We had this happen to us. We thought the fridge was dead. removed panel in the freezer compartment (in the back) and exposed the fan. Changed the fan, works good. good luck
Posted on Apr 19, 2013
maklean
  • 1665 Answers
SOURCE: Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas.
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer.
Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
Watch its operation more closely to see if any same symptom.
Posted on Jan 15, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    lojacksdad
    • 121 Answers
    SOURCE: bottom freezer, ice cubes melting and refreezing.
    defrost timer saying off to long
    Posted on Apr 17, 2009
    SOURCE: area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
    http://www.askmehelpdesk.com/other-home-garden/refrigerator-frame-hot-touch-31680.html
    Here's a link re the refrigerator symptom you describe.
    Posted on May 27, 2009
    • 100 Answers
    SOURCE: Ice Melting
    ok check the door gaskets they must be toushing forming a compleate seal nothing else is acceptible also there is a possibilty that your ice maker heater is stuck in the on position.also these units are known for a having a bad control boared in the back
    Posted on Aug 09, 2009
    Electrolux american fridge freezer cooling problem
    There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
    Dec 09, 2013 | Electrolux Refrigerators
    Ice Melting towards the front of the ice hopper
    Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
    Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
    Freezer drain may be blocked. Freezer not working effeciently the freezer always icing up
    . If the freezer is always icing up , you probably have the problem in your defroster circuit . The refrigerator cycles once every six to eight hours into the defrost mode . This is controlled by the defrost timer. when in this mode , a heating element located close to the evaporator heats up and melts the ice. This heating element will heat up any ice enough to melt It and drain out of the unit. I would check this first .
    Feb 19, 2011 | Maytag MZD2766GES Side by Side...
    My GE Profile Artica ice maker is making ice, but when I open my freezer, there are icicles from the ice compartment one the food below the ice maker and dripping down the inside of the freezer. The ice...
    Hi!!
    The Ice Maker and the Freezer/Fridge part of the unit work separate, that's why you get the ice made but the freezer can't keep it frozen.
    Most likely the condenser, located in the back of the freezer is all frozen and covered with ice pluggin up the air ducts to the fridge, preventing it from cooling.
    One quick solution will be unplugging the refrigerator and allowing it to defrost on it’s own or remove the freezer's back panel and using a heat gun or hair dryer to melt the ice, this will take about 20 to 30 min..
    There are various reasons this type of problem:
    The temp. controls are not set properly. Set controls according to manufacturer recomendation.
    The small fan in the freezer is not working,
    The defros timer is not working or,
    The defrost heater coil is busted.
    Once the ice is melted, plug unit back in and check for unit reactions. You should be able to hear the freezer fan working. Also, you'll hear about 4 to 6 times a day the defrost heater melting the ice in the back of the freezer, if NOT, check heater coil for continuity.
    Don't forget to rate this post. Good Luck.
    Jun 07, 2010 | GE Profile Arctica Stainless Steel Top...
    Freezer model EV171NYMS04 we have ice build up on
    There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
    Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
    Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
    FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
    Remove the food from the freezer compartment and place inside the refrigerator temporarily.
    Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
    CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
    If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
    You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
    Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
    In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
    Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
    Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
    Freezer just stopped working
    1. You need to unthaw the freezer, and it should start working.
    Sep 11, 2009 | Freezers
    My bottom refrigerator is not cold. The freezer is okay.
    Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
    Jul 22, 2009 | Refrigerators
    Ice forming on freezer
    The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
    Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
    Refrigerators Logo
    59 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
