Question about Canon PIXMA Office Equipment & Supplies
How do i get a confirmation page on canon mx892
How can I get a confirmation page to print on my fax machine
Joed911
  • 4338 Answers
SOURCE: Confirmation
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Posted on Oct 14, 2008
Joed911
  • 4338 Answers
SOURCE: Canon ImageClass MF6590
Press the plus or minus sign to get to the "Report Settings" then press ok.
Under report settings select "TX Reports"
then set "Output" to YES
under that set "report with TX image" to ON
This will give you a confirmation with the image of you fax. Here is the manual, info on pg. 251
http://gdlp01.cwss.com/gds/0300000953/MF6500_BASIC_en_us_R.pdf
Thanks, Joe
Posted on Dec 11, 2008
POCBM
  • 121 Answers
SOURCE: Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Posted on Mar 25, 2009
  • 46 Answers
SOURCE: how do i get my fax machine to print out
go into you fax options just look for conformation send or confirmation on fax error you sould be able to find those options in the general fax setup.
Posted on Oct 12, 2009
SOURCE: Photosmart c309a fax confirmation?
To enable fax confirmation via the device control panel
1. Press Setup.
2. Select Print Report, and then Fax Confirmation.
3. Select one of the following: On Fax Send, On Fax Receive, Send &
Receive
4. then press OK
Posted on Dec 11, 2009
Canon mx892 error code U052
Please try the following to see if we can resolve this error:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
Once this has been done, plug the power back in and turn the printer on. If the error persists, you will need to replace the print head
Canon PIXMA MX892 Mfr # 4546B007 $45.00
May 03, 2014 | Canon PIXMA MX892 Wi-Fi Inkjet Office...
How can I download the canon pixma mx892 printer software
Hi nancy,
your driver can be downloaded simply by using this software: http://tinyurl.com/lhv2nua. wish you best of luck
Dec 24, 2012 | Canon PIXMA MX892 Wi-Fi Inkjet Office...
Canon MX892 - when I scan, an error code 2156 comes up saying scanner is turned off or usb cable unplugged
Hi.
Try to check up first scanner power cable and network wireless router.
If it are running running good. your scanner have defective parts. like
IC chipset.
Second option : try to general cleaning your Canon PIXMA MX892 Network-Ready Wireless All-In-One Printer. using vacuum.
Hope can help you.
Sep 15, 2012 | Canon PIXMA MX892 Network-Ready Wireless...
How do I print a confirmation page for this fax
1. First You need to press the additional functions button on the front.
2. Select Report Settings button
3. Select Printer button under the Print List menu
4. Press either PCL button or PS button to print the appropriate config page.
5. Press Configuration Page button
6. Select Yes button to confirm printing of config page.
Feb 19, 2010 | Canon LaserCLASS Fax 710 Printer
How do I print a confiramtion page to make sure my
Press Funktion and then report-activity reports will be displayed press ok.Or you can go to funktion-datarigestration-scroll to reports,press ok,select TX report,select output yes.Then after you send a fax a tx report of the fax you send will be printed out.
Dec 08, 2009 | Canon FaxPhone L75 Plain Paper Laser
FAX MACHINE NOT PRINTING CONFIRMATION PAGE
How do you get a confirmtion page after faxing on a Canon 3235i imagerunneer
Sep 08, 2009 | OKIFAX 5650 Plain Paper LED Fax
Automatically receive a confirmation page after sending fax
please ser send my experties your machine model then i shall help you
Aug 05, 2009 | Canon ImageRUNNER 1670F Copier
How to have fax confirmation sheet print
open both one-touch speed dialing panels--press DATA REGISTRATION >set> press search buttons to display REPORT SETTING >set> search to OUTPUT YES (This will print a report with every transmission, next option will give you the option of whether to print the first page of the document (yes) to remind you of what it contains)
Mar 18, 2009 | Canon LaserClass 9000L Plain Paper Fax
Confirmation pages
press function
press dataregistration
press set
use scroller up and down to select the function that you want to do, there's a lot of function, like user setting, report setting vvvvv.
select user settings, then scroll up or down
select activitiy report, then set it auto print off
will help you, play around with it.
Oct 22, 2007 | Canon FAXPHONE L80 Laser
117 people viewed this question
old marine
old marine
