Question about Proform Exercise & Fitness
Petl 40507 proform 3.6 pf
Belt won't turn
4 Suggested Answers
  • 1156 Answers
SOURCE: Proform 345S Crosswalk owned for
unfortunately, the manual for your Proform 345S Crosswalk unit is not available anywhere online. The manufacturers of this Unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of your Proform 345S Crosswalk via phone or e-mail and request for the manual from them. They might give it to you or direct you to a dealer where you can get the manual.
This is the best you can do to get the manual you are requesting for.
Below are the list available manuals and models for Proform 345S Crosswalk
http://www.hammerwall.com/Manuals/ProForm/251/
Good luck..
Posted on Jun 17, 2011
ercupa190
  • 12223 Answers
SOURCE: proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: Proform 470 treadmill, belt won't run
see the video attached:
1) LUBE THE DECK BELT
2) LUBE THE ROLLERS BEARING
3) if this NOT has solution , you must test the a) motor y/o main motor board see the block diagram
God bless you
Posted on Aug 01, 2012
My Proform 770 EKG treadmill's motor is overheating. What is the voltage that should be pulled during use? Should the walking belt be replaced if we replace the motor?
see the video and lube correctly. 2) go to my personal TIPS for motor help.3) however you must see the voltage in the plate of motor. the tolerance will be +- 10% of voltage. can be voltage continuosly or alternating voltage.God bless you6527db9f-a9f8-47a6-9208-af2b680ea3a0.jpg
Apr 01, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
Proform 560 crosstrainer treadmill powers on belt won't turn
LUBE THE deck belt+ rollers bearing too. God bless you
proceed according with the video attached.
Jan 07, 2013 | Proform Exercise & Fitness
Makes grinding noise and belt won't move
If it sounds like metal rotating on metal then it could be a a(roller bearings or b( motor bearings. LUBE INMEDIATELY. + DECK BELT LUBE VERY URGENTE, MAYBE YOU HAVE A WORN DECK TIME TO CHANGE THE BELT.
God bless you
Oct 01, 2012 | Proform 380 Treadmill Walking Belt
My treadmill won't run, but turns on
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
Aug 31, 2012 | Proform Exercise & Fitness
I have a Proform xp 550 the incline won't go up...it was starting to go up then made a noise and it dropped down ... how do i fix it?
RUN the software calibration for diagnose, troubleshooitng, fix it.
2) Lube the gear+shaft from elevation Motor
3) adjust the POT from elevation motor, see diagrams attached.
God bless you
Aug 02, 2012 | Proform XP 580 Trainer Treadmill
God bless you
Jul 31, 2012 | Exercise & Fitness
Proform 730 treadmill,rusted screws won't remove to replace walking belt
Use WD40. Or go to a nearby hardware store an purchase a rust remover. Aply either one and wait for a bit. Then remove screws.
May 06, 2012 | Proform Exercise & Fitness
Proform crosswalk 515 control board works but belt won't move/
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
Proform pf 3.6 problems
My tredmill wont unfold - i dont know how? Help??
Feb 29, 2012 | Proform Exercise & Fitness
Belt stop working. All lights lit.
HAPPILY WALKING ALONG AN THE MOTOR JUST STOPPED. aLL OTHER CONTROLS STILL WORK. jUST THE BELT AND MOTOT WON'T FUNCTION.
iS THERE A PART ON THE POWER SUPPLY THAT HAS BURNED OUT?
May 16, 2010 | Nordic Track /proform Treadmill...
Exercise & Fitness Logo
164 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
