Question about Acer X110 Projector Svga Dlp 3D, Eco, Cbii, Zoom, 2.2Kg, 4000:1, 2500Lm
My Acer X110 DLP Projector shuts down with a message "fan failure"
It boots but shuts down after showing this message.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
Clean the fan if you have blower do air service. otherwise open it and clean the fan.
if fan totally not working then need fan replacement.
Posted on Nov 30, 2017
4 Suggested Answers
SOURCE: i have a dlp acer projector when i connect it to
Kindly contact to Co's service center.
Posted on May 10, 2009
  • 105 Answers
SOURCE: Acer pd120 projector
get a bottle of canned air. blow out unit. take bulb out and clean everywhere every time you change bulb. let it sit for a while so it warms back up prior to plugging back in.the air gets cold
Posted on Jun 07, 2009
  • 138 Answers
SOURCE: my acer lcd projector not showing display, its
I suggest call for assistance for that product or replace the bulb of your projector.
Posted on Sep 20, 2011
My tool improper shut down detected checking file system please help me
that message appears if the shut down process is not followed.
power failure , emergency shut down or other problems that just shut the pc down will result in files and folders becoming corrupted and not saved
when booting up if the message appears that states start in safe mode , start normally etc , click on start normally
Oct 25, 2016 | Computers & Internet
I have replaced waste toner unit with new one on a WC 5050 and still shows the error message as full so unable to print
Reset to Default settings, if that does not work, shut down printer, unplug power from printer, shut down computer unplug power from computer, wait 20 seconds, plug power in to computer plug power in to printer, wait 5 seconds, boot computer, turn on printer.
NOTE: This should solve most problems with printers.
If still not working you have a faulty Toner unit.
Sep 21, 2013 | OKI C9600hdn Laser Printer
KDL52EX700 shuts down and restarts
If it is showing a blue scree of death (BSOD) and shuts down before you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down below Safe Mode and you will see an option to Disable Automatic Restart. Select it and reboot your machine. Next time it boots up you will be able to read the error message. You'll probably need a system disc or repair disc to fix the blue screen error message.
Mar 26, 2012 | Computers & Internet
MY Dell laptop running XP will run in safe mode but shut down after 2 minutes in normal operation. When I start it defaults to safe mode but allows me to restart and comes up temporairialy in normal mode...
Hi Friend, If your system only boot up in safemode, you should try a Clean Boot of your machine to help given steps, 1- click Start, and click Run. The Run window appears(From the safemode desktop) 2-. In the Open box, type msconfig and then click OK. The System Configuration Utility appears. 3- go to the General tab and click Selective Startup radio button. 4- Un-check all options with the exception of "Load System Services" & "Use Original BOOT.INI". 5- Click Apply, and then click Close. 6- When prompted to restart the computer, click Yes. Now if it boot up in normal mode you should get a message to the effect of the changes you just made in msconfig, don't worry about it, but make sure you put a check in the box that says "Do not show me this message again" and click the "OK" button.
Jan 01, 2010 | Toshiba Satellite A100-S8111TD Notebook
My laptop shuts down right after booting up. It shows a blue screen witha message about checking the configuration of drive c. It gets to about 75% complete and shuts off! HELP!!
Try to boot up in safe mode, done by pressing F8 while computer is booting up then restart and let computer boot up regular, if you installed any drivers before this happen unistall them while you are in safe mode.
Nov 21, 2009 | Toshiba Satellite A105-S4034 Notebook
Boot Error Shutting Down Sony NWD-B103
down load teh latest firmware from following link & update your player...............cheers....!!!!!!!!!!!!!!
Apr 23, 2009 | Sony Audio Players & Recorders
Laptop caught up in reboot sequence
Do you have the case speaker connected? If so listen for the bios beep codes. You will have to know which bios you have.
Dec 27, 2008 | Microsoft Windows XP Professional
Presario will not stay on and error message appears
Sounds like your harddrive controller on the motherboard has failed.Boot into the bios and see if the harddisk is reconnised if not (which i am sure it is not) the you need a new motherboard ,sorry!
Dec 15, 2008 | Compaq Presario 700 470024-192 Notebook
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
Acer X110 Projector Svga Dlp 3D, Eco, Cbii, Zoom, 2.2Kg, 4000:1, 2500Lm Logo
446 people viewed this question
Top Acer Office Equipment & Supplies Experts
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
