Question about Technics SL-1210 Turntable
Top panel bubbling and peeling off
Have recently got our turntables down from loft, they have been boxed up and have been up there for approx 12 months. when we looked at them the top black panel seems to be peeling and bubbling, I am trying to make a claim on my house insurance for them as they went up fine with no problems, there is no damp in the loft and nothing has been spilt on them, the box was not damp or wet either. insurance co says cannot claim unless valid reason for this problem, and advice please? kind regards
  • 89 Answers
I would suggest that the humidity and high temperatures in your loft has weakened the glue that holds the laminate onto the base. Temperatures in lofts/attics can be very high during the summer months.
Posted on Mar 13, 2009
Why does my turntable not spin when I move my Tone arm over?
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 30, 2011 | Sony PS-LX250H Turntable
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
I just moved, trying to reconnect set top box Teac HDB843, but it says 'no signal' on tv screen
I would suspect that if you have just moved you may not have an aerial connected. If you can't see one outside or in the loft then that is the problem.
pete
Dec 15, 2010 | Televison & Video
There are chrome rims on the car I bought about 4 years ago. I took the car in to discount tire because one of the tires continue to go flat on a weekly basis. I was told that the rims got wet inside which...
moisture in a mounted tire will rust a steel rim from the inside out with chrome it gets under the chrome plating and attacks the steel rim which peels,flakes and bubbles the chrome off if it hasnt damaged the outside of rim[meaning re chrome or replace rim] and only at rim lip u can sand lip till smooth and theirs a brown sealer that almost every tire place use and can be put on tire lip which seals stopping any rim lip leak this stuff is use for problems like yours imperfections on rims---doesnt matter where u live the moisture has nowhere to go they will have the moisture in there
Apr 26, 2010 | 2007 Chrysler 300c AWD Sedan New Cars
I WANT TO BE ABLE TO SEND SKY TV SIGNAL TO ANY ROOM, i HAD THIS IN OUR LAST HOUSE BUT CAN NOT REMEMBER HOW i RUN ALL THE COAX CABLES. i HAVE AN APLIFIER IN LOFT WHICH CABLES TO EACH ROOM, SO DO i NEED TO...
put coax from sky box output then into splitter in loft ampifier and conect all other coax that run down to other rooms to the outputs in amplifrer and turn on sky and put menu on then tune tv's in on anolog station
Dec 20, 2009 | Panasonic TH-42PX60U Television
Need to repaint bubbled and peeling paint on top of dryer
The choice is yours. Money often motivates these decisions. If the model number you have this listed under is correct, the top panel price is roughly $108 to $160 depending on the color you need. White or Bisquit is the cheapest, while Pewter is the most expensive. If you wish to replace it, appliancepartspros.com carries it for the cheapest price.
If you wish to paint it, remove the panel from the dryer first by locating and removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. This will allow you to work on it in a more convenient location and avoid any overspray from paint on your appliance. Make sure you clean the surface throughly to remove anything that may have caused the paint to bubble and peel in the first place (Ospho is commonly used to clean metal surfaces in preparation for painting - clean AFTER you sand). I would sand with a fine grit sand paper or emery cloth to ensure you don't leave any surface scratches. Prime the entire panel to provide a good surface for the new paint to adhere to. Once the primer is dry, apply a couple of good coats of appliance paint. If you have questions, please let me know. I hope this helps you.
Sep 06, 2009 | Whirlpool GEW9250 Electric Dryer
Plastic over the outer edge of jog wheel on cdj800 is peeling
The jog wheel assy' is in several parts. email me a picture and I'll get you a price for the part you need.
mail@technicsdjuk.com
http://stores.ebay.co.uk/methleykev
Jun 27, 2009 | Pioneer CDJ-800MK2 Turntable
Overlay Panel bubbles up!
I had the same oven panel overlay bubbling problem on my GE oven purchased in 2008. It started peeling and bubbling within the 1 yr warranty, and GE sent me a replacement panel. This new part began bubbling again within 4 months. Again, I called but now they say it's out of warranty and they will not replace it. Obviously there's a manufacturing defect in this part. The panel looks terrible. It appears that GE no longer cares about the quality of their products.
Jan 02, 2009 | Ovens
Technics SL-1210 Turntable Logo
203 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
