Question about Sharp XR-10X Multimedia Projector
Sharp PG-A10X wont turn on - Sharp XR-10X Multimedia Projector
3 Suggested Answers
SOURCE: Sharp Notevision PG A10X
check the power supply heard issues with this system like that but was all related to the power supply
Posted on Jan 24, 2009
johex
  • 75 Answers
SOURCE: LCD projector shuts off durning use
u have not mentioned how long u have been using this projector. either the lamp life is low or the circuitry protecting the lamp temperature is defective or even the air intake of the fan is inadequate, a filter is fitted for air flow if this is clogged or blocked, lamp temp will rise and unit shuts down. if lamp indicator is yellow or red it is time to change the lamp. if it is red - lamp is totally out, if u turn on the unit four times without replacing lamp, the unit simply wont turn on. one other possibility is power cable and power connections. check power cable too.
Posted on Apr 07, 2010
What can cause my sharp pg a10x not to have any power at all
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 24, 2014 | Sharp (BQCPGA10X1) Projector Lamp for...
Rest light imer on sharp pg c45x
Turn on projector, press and hold the input, enter and undo buttons on
the projector then while still holding those three press the on button. Make sure you do this before the timer goes to 0% or it wont turn on again.
Apr 21, 2011 | Sharp Notevision PG-C45X Multimedia...
All button on projector locked
hi,
do the fallowing setup and try again.
ok
p { margin-bottom: 0.21cm; }
If you forget the password, delete it using the fol-
lowing procedure and set a new password.
1 You can only use the buttons on the projector
to delete the password.
2.The password cannot be deleted using the
above described procedures while the "Anti-
Theft" function is set. If you forget your pass-
word while the "Anti-Theft" function is activated,
Dec 29, 2010 | Sharp Notevision PG-A10X Multimedia...
Apr 07, 2010 | Sharp Notevision PG-A10X Multimedia...
Replaced lanp and the unit will not power on
you need to reset the lamp timer. hold down the enter, down, and menu, then press power.
Dec 17, 2009 | Sharp Notevision PG-A10X Multimedia...
Replaced lamd power and lamp light are green for
Yes you need to replace lamp,so you buy a new lamp.
Dec 14, 2009 | Sharp Notevision PG-A10X Multimedia...
Where are the fuses in a Sharp xg-nv3xb notevision3 projector
Main line fuse is on the board where the ac cord plugs.
The caps in the power supply usually leak and explode after 5 years, blowing the fuse. Solution is to replace the power supply and lamp ballast boards. Expensive repair.
Nov 09, 2008 | Sharp Notevision PG-A10X Multimedia...
Aug 21, 2008 | Sharp Notevision PG-A10X Multimedia...
Projector
Does the temp. light come when it switches off ?
Check if all the fans are running when switched on.
If all the fans are running - take out the lamp and check if you can see any irregularity on the shaft of the lamp's insides.
If not then you will most probably have the Ballast ( Lamp's powersupply ) replaced or repaired
Apr 02, 2008 | Sharp Notevision PG-A10X Multimedia...
Sharp XR-10X Multimedia Projector Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
