Question about Garden
What engine oil do I use in a Honda GV100 lawnmower please.
4 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: how much oil does a mountfield omega lawnmower take
If it is a small horsepower engine 4, 5, 6 HP, it will take approximately 20 ounces. If it is a larger engine8, 9 ,10, 11, 12 and on up it will take from 40 to 48 ounces
Posted on Sep 15, 2009
  • 168 Answers
SOURCE: no spark on GV100 honda engine mountfield laser
I assume you replace the coil due to the fact you didn't have any spark. If so, make sure you have the leg gap to flywheel correct. 12 thou should get you spark. However, if still no spark, check out the switch at the lower section of the cable. May only need an adjustment there, as the old cable do stretch with time and the gap is now incorrect. Make sure when you engage the cable that the switch isn't still grounded. Also, check the flywheel key to make sure it's not sheared off. Good luck
Posted on Oct 09, 2009
Knucklebstr
  • 222 Answers
SOURCE: On a Honda GV100 lawnmower
You need to clean or rebuild your carburetor. If you're so inclined to do it yourself, there are many great videos on youtube. Here's a good one that shows a Tecumseh carb, but they are all basically the same once you get them off the machine. The problem I have with the Honda's is aligning all the parts and gasket when putting them back on. Here's the link and you can search for more. As I said, there are plenty of videos, and once you do one, successfully, you'll get the hang of it. Otherwise, take it to a professional for a good cleaning. Best of luck.
http://www.youtube.com/watch?v=i0JfCPxY3po
Posted on Jul 02, 2011
How much oil do i use in my gv100 honda?
drain oil when warm then add oil to it still safe on filler dipstick oil reaches the that level it is full
Sep 01, 2014 | Garden
My lawnmower stopped
Check the oil. I bet you seized the engine.
May 18, 2014 | Honda HRC216HXA Commercial Lawnmower
Honda gv100 cutting out
Bad plug. Bad gas. Dirty carb. Dirty air cleaner.
Aug 21, 2012 | Honda Garden
I have a gv 100 honda engine on my lawnmower and it is pulling in oil from a breather pipe into the air filter can anyone tell me why
indicates excessive oil in the sump ( check float is not stuck and fuel in leaking into the inlet manifold and into the engine sump)
ring problem allowing excessive blow by into the sump which is collecting oil vapor as it exits to the air filter
May 12, 2012 | Honda HRX217VKA Lawnmower
Honda gv100 lawnmower blowing eng oil out of breather pipe intoairfilter resulting in excessive smoke from exhaust
I think that will find that the wire strainer has become blocked in your engine breather system. Unfortunately the engine breather for your engine is located under the flywheel, the flywheel will have to be removed with a puller as this is a taper fit on the engine crankshaft and usually a very tight fit ( especially if it has never been removed before ), once removed you will find a small cover held on with two 6mm bolts, remove the cover and you will see a wire stainer, wash this out, and if possible blow it through with compressed air until you can see through the wire strainer when you hold it up to the light, refit all parts and hopefully you will have many more years service from your lawnmower, I write this as I have a garden machinery repair business in Chedzoy, Somerset, England and have had a very similar problem with a customers lawnmower, best of luck and happy mowing.
Feb 01, 2012 | Garden
On a Honda GV100 lawnmower engine will start for about three secounds and stops, seems a fuel problem in the carb any ideas? Vic
Jun 30, 2011 | Garden
Where is the oil plug underneath the mower?
Depending on what engine is on your Toro lawnmower, there may not be a oil plug under the mower deck. A briggs and stratton engine will have one, but if the unit has self propel then you will have to move the guard over the self propel cable. This is a 1/2 in bolt, you will also have to loosen the other bolt to swing the guard around.
On a Kawasaki or Honda, and even if you have a Tecumseh engine then just start the mower up for a few minutes and let the engine oil get warm, then shut the engine off and then lay the mower on the side that has the oil filler cap and put your drain pan under the oil filler cap. You can then drain the oil out of the oil filler tube. You can also do this with the briggs and stratton engine. I find this to be a very convenient way to change the oil.
Then put fresh oil back in the unit. I always suggest to put the engine manufacturer's oil back in the unit, or if that is not available then use another oil from another engine manufacturer. IF you use automotive oil, the oil will break down faster since the heat level for the engine on car is less than that of the engine on your lawnmower. The engine has a water cooled design, that keeps the engine temperature from raising over about 250 degrees F. The engine temp on your lawnmower can get as hot as 400 degrees F in the summer heat and being run for 30 minutes or longer.
A longer answer than you had hoped but I hope the information keeps your lawnmower running well for many summers to come. :)
Apr 04, 2011 | Toro Power Lawn Mower
I have a honda gv100 lawn mower and there is no petrol going to the engine
I have a mountfield omega petrol lawnmower with a gv100 honda engine. I turned it upside down to replace the blade and now it won,t start. Any help would be appreciated
May 30, 2010 | Honda 8 HP Engine
Smoke from engine of lawnmower
usually large clouds of smoke are from having too much oil in the crankcase, or tipping the mower so that oil runs into the cylinder. Check the level of oil, and make sure it's not overfilled.
Mar 26, 2010 | Pool & Spa
Garden Logo
344 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
