Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
HBW1241 Can Not Change Remote Battery
Hello, I can not open the back of the remote control to change the battery. Any suggestions? Thanks so much!
  • noellead Apr 19, 2009
    I have the HBW1573, and have the exact same problem. There appear to be two places on the body of the remote where you can wedge a small coin (I tried a dime) to open it, but I can't budge it, and seem only to be damaging the plastic.....can anyone help?
I have the same remote. You need to wedge in a flat-head screwdriver. Push it into the plastic and turn. This will release it from the catches. Now I just have to find out where to get the flat 1/2" lithium battery to replace it.
Posted on Aug 02, 2009
  • 463 Answers
9v Battery Compartment? Little screw under the battery perhaps?
Posted on Mar 11, 2009
How to fix digital stream remote control
1) try to change a new batteries by the same type of batteries and full charged
2) clean the contacts battery with contacts cleaner
3) retight the springs contacts battery with pliers for better contacts
4) resolder the wires contacts battery
5) open the remote control and clean the keypads switchs with contacts cleaner for dirty, dust, oxide, bad contacts, open contact with VOM and fix it. Remember they receive signal from Syscon and emite infrared signal to the receiver
Otherwise you mus go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Televison & Video
How do you change the batteries?
Remove the Battery cover on the back of the remote. Remove the dead batteries. Put them in recycling Open the new batteries and install them paying attention to polarity. Replace battery cover
May 06, 2011 | One For All URC-4330 Remote Control
Remote does not work unless I am in the garage. Outside the door it will not work.
hello emar... check to be sure that the little wire antenna is hanging down from the back of the garage door opener motor. Then check it. If it still won't work from outside, install new batteries.
If that doesn't do it, remove the new batteries and use the eraser end of a common pencil to clean the battery contacts inside the remote. then reinstall the new batteries and try it again.
May 04, 2011 | liftmaster 83lm Billion Code 3-button...
Mx350 will not work through our cabinets and will work some days and not others
Hello...To response to your problem about the Universal Remote..Just change your battery in your remote .. the remote will work with weak signal if your battery are low
Oct 15, 2010 | Universal Remote Control MX-350 LCD Remote...
Need help changing batteries on Wave Radio remote
Setting up the remote control
WARNING: Keep the remote control battery away from children. It may cause a fire or
chemical burn if mishandled. Do not recharge, disassemble, heat above 100°C (212°F), or
incinerate. Dispose of used battery promptly. Replace only with a battery of the correct type
and model number.
Your remote control may be one of two types. Each is identified by the way
the battery compartment unlocks to install or replace the battery.
1. Place the remote control face down on a flat surface.
2. If your remote has a slot on the back, follow step A. Otherwise, follow step B:
A. Insert the tip of a ballpoint pen into the slot. Push to the side as shown and hold. Slide
the battery compartment open with your finger.
B. Using your finger, push the tab lock to the side as shown and hold. Slide the battery
compartment open.
Setting Up
See operating
instructions for types of
battery to be used
Note: Use only a Duracell, Eveready, Maxell, or Toshiba CR2032 or DL2032 lithium battery
(available at electronics stores). If you have difficulty finding a replacement battery, contact
Bose® Product Support (see phone numbers on the inside back cover).
3. Keeping the remote control face down, insert the new battery into the compartment with
the + symbol facing up.
4. Gently slide the battery compartment closed. It locks automatically.
5. Use the supplied mounting strip if you want to attach the remote to a surface in your
listening room. Peel off the protective backing to stick one piece to the back of the remote
and the other to the selected surface.
Jul 18, 2010 | Bose Wave radio remote control - Graphite...
Remotes will not work
change sensor of your remote control ,if there is not solve than change your sensor of your tv
Jun 02, 2010 | LG 42PG20 42 in. Plasma HDTV
How do i change the battery for the RTI universal remote... i believe it is the battery because it does not hold a charge. And if I change the battery does the remote keep what has been programmed in it....
The remote keeps it's memory in a non-volatile memory chip which is unaffected by power loss. So changing the battery is safe. The replacement batteries can be ordered from your RTI dealer for $45. Be careful with a T1 battery connector, they are delicate and can pull away from the board leading to an expensive repair. I'd suggest taking the remote to your dealer and have them replace it for you.
Apr 06, 2010 | Rti Technologies Rti T1 Remote Control
My chamberlaain security + garage door openers
well your main PC board inside of the opener head could have lost the frequency, or the unit memory has been erased, try to reprogram the remotes by going to the back of the opener head and locating the "learn" button which is either red, green, or purple in color. press the learn button then ONE button on ONE remote, pressing multiple buttons or pressing both remote buttons at the same time will not allow them to be programed successfully. after programing test by pushing the same button you just programmed, repeat for other remotes, and if this process did not work than you will need to contact chamberlain
Jan 17, 2010 | Chamberlain 950CB Remote Control
Change battery in GICT390 3 button remote
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries.
Oct 10, 2009 | Genie Company IntelliCode GICT390-1BL...
Hello, I have a LG 42" plasma and the remote control doesn't work with the tv. I just call LG and they said it shoul be the remote control sensor on the TV......I don't know. Do you have any...
Good Day;
LG might be correct, but try these suggestions first;
1.) Change the batteries in the remote, and make sure they are properly installed; positive (+) to (+), negative (-) to (-).
2.) Take remote control to local TV service center, have them check it out.
Good luck, j73.
Jul 08, 2008 | Televison & Video
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
1,762 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
