Question about HP (A2839B) Mouse
Mouse doesn't recoonect
I unplugged my mouse, reconnected the to the usb port, pushed connect button--nadda. the light is on, but not on the reciever when I move the mouse. receiver will flash when I plug it in
  • mike mench Mar 11, 2009
    that did'nt work, but thanx
    Hp m971au and if U can give me the steps to reinstall it I'm a computer dummy
    Problem Solver:
  • 11 Answers
With the usb plugged in, restart the computer. If you move the usb mouse from port to port while the computer is on it may not recognize it. I hope this helps and please let us know. Please rate. Thank you.
Posted on Mar 11, 2009
  • Timothy Bright Mar 11, 2009
    Is your mouse working yet? If not you may want to try and reinstall the driver for the mouse. If you could inform me on what kind of mouse it is (make and model) I could look up the driver for you.
How do I connect my Logitech wireless mouse to my computer
I use Logitech wireless mice and so does my wife. After a battery change you have to reconnect the mouse with the wireless receiver
. First push the button on the receiver, then push the button on the bottom of the mouse. It should connect and you will be ready to go. If this doesn't get the mouse working, you may have to unplug the mouse, then plug it back in the USB port, then reconnect to the receiver. Hope that helps.
Sep 30, 2014 | Logitech Cordless Mouse
I have a compucessory wireless mouse and keyboard. Mouse model 40918. My mouse just stopped working this morning. How do I get it to reconnect?
check the batteries on the mouse
usually on the underside of a mouse possibly under a plastic sticker rub your fingernail across the top to locate a small (phillips screw) star screw make sure they are connected you can do this by spinning them around and fully charged
hope this heps
Oct 25, 2011 | Compucessory Wireless Optical Mouse...
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
My computer doesn't recognise my unifying reciever, i think it may be damaged
Try unplugging and replugging the receiver. You should hear the beep-beep sound as you disconnect the USB device and again as you reconnect it.
Then check in the device manager to see if it has been recognized.
After that, push the "connect" button on both the receiver and the underside of the mouse to establish a connection.
If all that fails, you are probably correct. (just to check--are the batteries in the mouse good?)
Nov 08, 2010 | Logitech Cordless Mouse
It was working a minute ago and then froze on me. The mouse shows red light but the contact device that is plugged in doesn't light up at all now
Try reconnecting the mouse to the contact device by pressing the connect button on the device first then on the mouse.
If that doesn't work replace the batteries on mouse and folllow the steps above.
If the "contact device" is usb based(flat plug not round) unplug it from the computer and plug it back in another available usb port.
Mar 08, 2010 | Logitech Cordless Mouse
I just got a hp optical wireless mouse and reciever,product no. is gm323aa,I checked the batteries,changed usb ports,pushed button on reciever alone and at the same time as the button on the...
make sure u installed your mouse properly...
also make sure that your usb point is correct....
make sure that the mouse u purchased is working....
Oct 04, 2009 | HP GM323AA Mouse
Receiver will not light up so the mouse nor the receiver works? help
The reciever for this mouse does not have a light, however, your USB might be a dud (on your computer) so try another port. Also replace the batteries inside your mouse with new ones. This should fix the problem. Then reconnect them with the button on the reciever. Also make sure to hit the power button on the bottom of the mouse. If this does not work, then your mouse if fried and you need a new one.
Oct 02, 2009 | Logitech LX5 Cordless Optical Mouse -...
We have a wireless keyboard and mouse and it seems that something between them and the computer is slow or off. we type and only a few letters appear..the mouse seems to be ok just kinda slow ofrom when...
Most likely you need to re-sync the device
  1. Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers. Use the following steps to resync the devices:
    NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
    1. With the receiver plugged in, press and hold the Connect button on the receiver until the activity LED flashes.
      NOTE: Some HP computers have receivers built into the front of the computer; such as TouchSmart 700 Series PCs and Digital Entertainment Centers. Look for a small connect button built into the case. If you have a TouchSmart 500 or 800 Series PC, the receiver plugs into a USB port on the underside of the case and does not have a connect button - skip this step. Figure 4: An example of a receiver c01065862.jpg 1 - Connect button and LED activity light Figure 5: Another example of a receiver c00526313.jpg 1 - Connect button 2 - Num Lock LED 3 - Alpha Lock LED 4 - Scroll Lock LED 5 - Activity LED
    2. Press and hold the recessed connect button on the underside of the keyboard until the activity light on the receiver stops flashing. When you release the button, make sure it does not stick in the depressed position.
      NOTE: If problems persist after resetting AND there is another wireless keyboard or mouse near, use these steps again, holding down the keyboard or mouse button for ten seconds. Doing so may give the keyboard or mouse a new ID number in case the other keyboard or mouse was using the same number.
    3. Press the Connect button on the receiver again until the activity light flashes.
    4. Press and hold the recessed button on the underside of the mouse until the activity light on the receiver stops flashing. Make sure the connect button does not stick in the depressed position.
  2. If your mouse and keyboard have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
Hope this helps!! Good luck!!
Sep 17, 2009 | HP Wireless Optical Mouse
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
My wireless mouse and keyboard have not been working lately. i use the on screen keyboard and use a wired mouse temporarily. can anyone telll me how to fix both the wireless mouse and keyboard? Also the...
Check the batteries first to ensure they are good. Do you have a receiver and is it plugged into the USB port?
You probably already know how to reset/connect the Keyboard and Mouse.
But here is info to help if you are not sure how to do it.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 30, 2008 | HP Multimedia Cordless Keyboard/Mouse...
HP (A2839B) Mouse Logo
211 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
