Panasonic TH-42PX8A update firmware - Televison & Video
2 Suggested Answers
SOURCE: Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
Posted on Dec 18, 2008
Firmware update
Your tv will update firmware automatically, it may warn you not to shut it down during the process. However having said that if you go into your main menu, you will see a first time startup option, follow the links and you will see an option to "update firmware" choose this option and it will update. Hope this helps
Mar 04, 2014 | Panasonic Viera TH-50PX80U Plasma TV
I'm wondering if there is a firmware update for my Panasonic Plasma and if so, how do I perform the update?
If you wish to get some details, check the site linked here. Pull up older posts. Firmware update procedure to many popular brand TVs are given in detail with illustrations.
Dec 10, 2013 | Panasonic Viera TH-42PX80U Plasma TV
No HDMI picture
I was interesting in asking HDMI picture really work.
You should tell us more briefly the terms.
Mar 10, 2012 | Panasonic TH-50PX75U Plasma HDTV
TH-42PX60U wont turn on. Blinks 10 times. replaced the power supply board, but the same issue.
What I'm learning is there are several models of Panasonic TV's that have a video card that doesn't play well with HDMI applications and the end result is, you need to call this number and not only make arrangements to replace the bad board,but also this!
Your model doesn't show below,but I'd certinly inquire about the necessity of a "Firmware" update!,,,Panasonic knows FULL WELL they have a HUGE problem here!
Hope this helps!
At panasonic.ca I found the listing for the fw update under customer support-important notices
If you own a plasma TV with model and serial number within the range specified below, please contact our toll-free VIERA Concierge hotline service at 1-866-330-0014. A VIERA product expert will arrange an in-home software update for your TV at your convenience.
Model Numbers Serial Number Range
TH-42PZ77U
TH-42PZ700U **71250001 ~ **80189999
TH-42PZ700UA
Jan 28, 2010 | Panasonic TH-42PX60U Television
TURNS ON THEN OFF, RED LIGHT BLINKS 7X
replace sc board and do firmware update or problem will come back!
Oct 24, 2009 | Panasonic TH-42PZ77U TV
Connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Mar 14, 2009 | ASUS Computers & Internet
Won't respond to volume or channel changes red light blinks 20x's when turned off.
It's definitely a firmware problem. I called Panasonic and they were very polite about the entire situation and sent me a SD card with the firmware update. If you don't have time and you're tired of listening to tv at the same volume there is a way to do a hard reset.
I figured that unplugging the unit would do this, but there is one other step that you have to do to ensure that this works.
Generally the power button on the tv is always in the "on" position, this is what allows the remote to work. In order to do a hard reset the on/off button must be in the off position. Make sure that is off, then unplug the unit, let it sit there for a minute or two and plug it back in. If the tv comes back on as soon as you plug it back into the wall/powerstrip then the button was not in the off position.
This isn't the best fix, you'll still need to get the firmware update but it will at least give you the ability to use your tv normally....well until it decides to randomly lock up on you again and you have to do this all over.
May 11, 2008 | Panasonic TH-42PX60U Television
Tv does not power on
If it blinks 7 times, your power supply is shot
If it blinks 10 times, a video board went bad.
Mar 28, 2008 | Panasonic TH-42PZ77U TV
PANASONIC TH-42PD60U
I had a similar problem where my TH-42PX60 would turn on but all controls were disabled. I could not change channel, input, volume or anything other than turning the TV on and off. I called customer support and they directed me to this site: http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/downloads1.asp to download a firmware update onto an SD Card. I inserted the SD card into the slot in my TV and powered it on. The update took about 3 minutes and I haven't had a problem since.
This is a link to the instructions to install the update:
http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/Firmware/PDP/PX60/UpdateInstructions.pdf
Nov 26, 2007 | Panasonic TH-42PX60U Television
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
Electro Med Services...
