Question about Gateway Computers & Internet
My c drive got switched with my d drive. its a 160gb hd. c drive now only say its capacity is 6.90gb drive got partitioned somehow
    Scholar:
  • 77 Answers
If this happened after formatting windows do the following:
WARNING: This is really "dangerous" and you can end up that windows will not start.. WHILE FOLLWING THE STEPS DO NOT RESTART COMPUTER UNTIL IT SAYS SO..
Steps...............
- Log on as an Administrator.
- Go to start, run
- type Regedt32.exe
- Click OK
- Go to HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
- Highlight MountedDevices.
- click the right mouse, click Permissions.
- Check to make sure Administrators have full control.
- Quit Regedt32.exe ( you can simply close it)
- Go to run
- type Regedit.exe.
- Click OK
- Find the drive letter you want to change to (new). Look for "\DosDevices\C:".
- Right-click \DosDevices\C:, and then click Rename.
- Rename it to an unused drive letter "\DosDevices\Z:". (This will free up drive letter C: to be used later.)
- Find the drive letter you want changed. Look for "\DosDevices\D:".
- Right-click \DosDevices\D:, and then click Rename.
- Rename it to the appropriate (new) drive letter "\DosDevices\C:".
- Click the value for \DosDevices\Z:, click Rename, and then name it back to "\DosDevices\D:".
- Quit Regedit.exe
Again run Regedt32.exe
- Change the permissions back to the previous setting for Administrators (this should probably be Read Only).
- Type in D:\boot.ini in Run in Start menu and press enter
- Somewhere in file there should be written "partition(1 or 2)".. If the number is 1 change it to 2. If the number is 2 change it to 1..
- Save the file
- Restart the computer.
PS: Please rate..
Posted on Mar 11, 2009
  • Veli Kerim Celik
    Veli Kerim Celik Mar 11, 2009
    PS: ONLY DO THIS If the problem occured after formatting windows..
DVDR3575H doesn't recognize replacement HD
Unable to FORMAT the HDD in the device? Perhaps remove the drive - hook it up to a working PC temporarily, and using a partition software program or you could burn a CD (I use PartitionWizard), delete any or all partitions on the new 160GB WD and make that drive UNALLOCATED and UNFORMATTED. Apply the actions as needed - only to that drive (this will at least allow your unit to recognize it properly). Once done, remove the drive from the PC, and put it back into your recorder - see if it recognizes it this time, then try and format it (in accordance with the type of file system the unit uses - which may differ from that of a PC). Replacement drives should be formatted to suit the unit they are intended for AFTER they are fitted, not before. Otherwise you run into compatibility problems (e.g. the drive won't allow recording/doesn't read etc., but might work in a PC). If this is the case, it may explain greyed out options and not being able to record to it. If you still have the original drive, check the jumper setting to be sure. If both old and new are set to CS - leave them as is - don't change that.
Dec 18, 2017 | Philips DVDR3575H/37
I am trying to partition and format 2 identcal Toshiba Laptop SATA HDD's. Using Windows Disk Management and Easeus softwares, both softwares are listing each harddrive capacity at 55gb. The actual capacity...
You would want to delete all partitions from the disk. That will get the raw space back. From there, partition; then, format. If you need more help, please ask, but from the experience level able; it sounds like you are right on track.
Dec 03, 2010 | Toshiba Computers & Internet
Hard Drive lost capacity
You cannot just 'loose' most of the capacity on a hard drive unless you have some serious issue and if that was the case, I would not even recommend you using it! What I suspect, because of its size, is that you are only seeing one of the formatted (recovery) partition. In order to use the rest of the hard disk, with the proviso that you want to keep the existing small partition, you need to create and format additional partitions. This is not a trivial task, but the following is the summary on where to find the facility: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk will be displayed with all existing partitions: after which you can use the context menu to delete/create partitions, Format partitions and assign a drive letter so that you can use the formatted partitions. Hope it helps: let me know how you go!
Jan 01, 2010 | Western Digital Caviar SE WD1600AAJS 160...
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Problem with hard disk partition
there is a default and a hidden partition on it.. consist of all the back-up drivers for the laptop.. i recommend you go to the lenovo site and search on how to access the hidden partition..
Sep 23, 2008 | Lenovo 3000 Y410 Notebook
Loss hard disc capacity
Did you happen to re-install XP before this happened? WinXP prior to SP1 can only "see" HD's up to 127G, so that might cause your problem...make sure SP1 or SP2 is installed, or try Partition Magic and see if that helps.
Feb 17, 2008 | Computers & Internet
Problem with 160GB HDD
Hi there! I think it's not possible to replace the diode as these components are machine soldered to the board. If a machine soldering facility is available to you, you could possibly replace the diode (choose the same diode model adjacent to the one which is damaged. All the best to u.
Dec 10, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
LACIE Porsche 160GB
What system is the laptop? File differences is the ext-hard drive FAT32 or DOS? Therefore XP [NTFS] is not 'seeing' its content. On the XP machine go to start/Control Panel/Admin tools/computer management/storage/removable storage/and check the file type
Sep 27, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
