Question about DCS Professional Video Inspection Scope 3.5" General Dcs300
Blue screen on DCS300
Received new DCS 300, put in battery, turned on unit, got blue screen with the words " no signal" in top right corner. The LED's dim and get brighter as you turn up or down on the dial. No image on screen , only blue.
3 Suggested Answers
  • 161 Answers
SOURCE: oven in DCS gas range doew not turn on
Well some of the older ones have a unit that is sorta like a pilot light which keeps you safe by not letting out gas before it ignites so as to not blow up. This macanism is probably bad. I use to replace them on Tappan ovens. They would last a couple of years and then would go out and to replace them then was about $80.00. Easy to do. They are usualy located inside the oven somewhere and look like a glass eye on one end with a small 1/4 inch gas line connecting to the other end.
Posted on Aug 07, 2007
SOURCE: Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Posted on Oct 04, 2008
Mio moov 300 screen alignment problem
Download the user manual online and look for factory resettings. Follow instructions and it should work. On my Garmin, the same thing happened. On Garmin, you turn the unit off, press and hold the top left corner of your screen, and turn the unit on while pressing the top left corner of the screen. You wait for 10 seconds and a black dot appears and requests you touch it. The dot moves around the screen and you keep touching it. Once done, your screen perimeter is identified and all the letters fall in place when you press them. Good luck!
Dec 02, 2012 | SNK Mio Moov 300 GPS Receiver
IT is a xxl 530 s tomtom. Do you keep the unit
While in drive view, tap the screen on the blue status bar, on the GPS signal strength. A new screen appears showing the battery charge level at the top right corner.
Dec 29, 2009 | Tomtom ONE XL GPS
My tomtom300 turns on but wont get signal
try to restore or reset to factory settings in the menu
Nov 18, 2009 | Tomtom GO 300 GPS Receiver
Gps 350
Press the Power button on the top right corner of the case.
If unit will not power on, battery may be dead. Try connecting car charger or power adapter to unit.
To charge battery faster, leave unit connected to power adapter or car cord. Press and hold Power button to turn unit off. Screen will show "Going into charge mode."
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
Dark blue screen with words: Cable, Digital TV, No SIGNAL. Brand new TV.
that says it all... no signal look at your owner's manual to set it for TV
May 22, 2009 | Initial DTV-322 32 in. TV/DVD Combo
Blue screen on my tv; lock on screen how do i remove it
Go to menu and look for lock function and turn off. blue screen. tv is muting video bucause it is not getting any input signal .
Apr 24, 2009 | Televison & Video
Need pinout for Alpine CDA-7940 head unit
facing the back of the 7940 the top left corner is pin 16 the top right corner is pin 9. The bottom left is pin 8 and the bottom right is pin 1. Only a few of the 16 pins are used due to this unit only having pre-outs, no internal amplifier on this unit. Pin 1 red (ignition), Pin 2 pink/black (interrupt), Pin 3 orange (Illumination), Pin 8 black (ground), Pin 9 blue (power antenna), Pin 10 blue/white (remote turn on), Pin 16 yellow (battery).
Feb 21, 2009 | Alpine CDA-7940
Blue screen No signal
Hi peed941,
Try pushing the input button on the remote, it sounds like you have accidently changed the input to anntenna.
Let me know if this helps and please rate this solution.
Lone99star
Jan 22, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
CD won't play
Your lens might be dirty.Open the cover of player and identify the lens.Its a little glass eye.Get a clean cotton cloth dipped in methylated spirits gently rub surface of lens. Give some time to dry and replace cover.You should be ok.
Jul 19, 2008 | Cyberhome CH-DVD 300 DVD Player
TV turning on and off
Air 2 is the source it's looking at for a signal - - where is the signal plugged into? and are you able to change the input or source to look at another?
Bill
Nov 29, 2007 | Akai PDP-5016H 50 in. HD-Ready Plasma...
DCS Professional Video Inspection Scope 3.5" General Dcs300 Logo
26 people viewed this question
Top DCS Home Security Experts
Lawrence Oravetz
Are you a DCS Home Security Expert? Answer questions, earn points and help others
