Question about Toshiba Satellite Computers & Internet
How to get my new Toshiba Satellite C850D-11K to startup
Its brand new I plug it in and pressed the power button and it want boot up
SOURCE: My brand new Toshiba SAtellite C850 F31Q screen stays black on startup. What can I do?
Got this from another site, since I had the same problem:
The problem is with the power settings, not the OS or anything else
Here are the fix steps:
1. Turn off your computer
2. Disconnect every wire from it (including power)
3. Disconnect the battery from the bottom of the computer. There will be two tabs labeled 1 and 2.
4. Re-plug in the power wire. (the battery should not be in the computer)
5. Turn on the power. The screen will work. Choose start windows normally. (if you get that screen)
6. Go to Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings
7. Choose Change advanced power settings
8. Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in.
9. Click Apply then OK
10. Shut down you computer.
11. Disconnect the power cord.
12. Re-install the battery on the bottom of the laptop, plug in the power cord, and restart the computer. "
Posted on Nov 18, 2012
SOURCE: Toshiba satellite a105 s4004 cannot boot
if the recovery disk would not run to load the program than your hard drive is probably bad have you been into the machine and seen the hard drive have a look at the front where the wires plug in and there is a slot for jumpers to select the hard drive function make sure its set for master only. most hhard drives will not have a jumper for master setting if there is a jumper make sure its set right .
Posted on Dec 08, 2007
kikoksky
  • 119 Answers
SOURCE: toshiba satellite A50 error code
try removing the memories, hard drive, optical drives and power on your computer. if the computer beeps it is an indication that your computer is working and one of the remaining part could be causing the no boot. if after removing all the parts your computer will not beep or the flashing amber light will not change it looks like you will need to replace your motherboard
Posted on Jun 19, 2008
SOURCE: my toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
Posted on Sep 30, 2008
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
Why doesn't my windows button work on Toshiba Satellite C850D
Check your keyboard driver is setup correctly in the control panel.
Jul 07, 2014 | Toshiba Satellite E205-S1904 Laptop
Toshiba satellite C850D-104 when playing videos on battery power the sound distorts very often but when plugged into the power it plays perfectly,what is the problem?
It seems you have unstable power in your Battery. It is not a good sign for your laptop too. it usually seems on who use their laptop for heavy works like video editing and playing games. You are suggested to Change Your Battery.
Thanx
Nov 10, 2012 | Toshiba Satellite C850D-ST2N02 : Laptop...
I turn on the power, the power light comes on and the hard drive light for about 3 seconds than off...and i never get a screen. what could be the problem
Hello
First Remove all power (adapter power Cord and Battery (for laptops))
Hold down the ON button for 30secs (dispersing internal voltage)
Plug the power cord in only (ie leave battery out, for the moment)
Turn on
If it worked replace battery.
If it doesnt
Start your computer and press down on the "F8" key to get into the "Advanced Boot Options" menu.
Click the "Repair your computer" option on the menu and press the "Enter" key.
Select your keyboard layout from the choices given.
Click the "Next" button to enter the "System Recovery Options" menu.
Choose "Startup Repair" from the menu and press the "Enter" key to start the repair on your startup disk.
Dec 15, 2010 | Toshiba Satellite A135-S2386 Notebook
Hello my toshiba satellite m35-s149 dos not boot power button stays on I can hear fan and also hearr it beep. but theres nothing on screen if u can giv me some advice appreciate it thanx
If you can hear the startup music, try plugging the laptop into a regular monitor and press FN+F5 to view your operating system. This will mean that your backlight has blown and you need to replace the screen. If not, oh boy, it could mean that your motherboard may have taken a dive. Before you trash it replace the meory chips, just in case they have become defective.
Aug 08, 2010 | Toshiba Satellite M35X-S149 Notebook
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
EToshiba Satellite A100-S8111TD - Laptop do not finish boot on startup
Upon powering on, press the F8 button to load other options, choose safe mode only and hit enter.
If you were able boot windows under safe mode, you can try to do system restore or uninstall any program you've recently installed which cased the problem.
If you were NOT able to boot to safe mode, you need to do full system recovery and re install the OS. Insert the recovery disc and press F12 upon powering on to load boot menu then choose CD/DVD rom.
Hope this helps,
Sep 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Slow startup
ok, you need to recover your computer, press the power button, and at the splash screen, press the F11 key and follow the instructions on the screen. if you have any other questions, email me at meanness628@aim.com
Jun 28, 2008 | Toshiba Satellite A45-S151 Notebook
Can not open windows xp os
At startup you should see a prompt to press F12 or another key combination to select a boot menu. Then selcet the CD/DVD drive, then you should get a prompt to press any key.
If that doesn't work, then boot to the BIOS setup (Again there should be a prompt at boot to go to setup, then change the boot order to CD/DVD, save settings and exit
May 18, 2008 | Toshiba Satellite A100-S8111TD Notebook
Boot failure
does it beep at all?
take it into a dark room, can you see anything on the screen, even if it's very faint?
take battery off and plug in same thing?
Jan 04, 2008 | Toshiba Satellite A105-S4004 Notebook
Won't startup
Try removing the battery and the AC adapter from the laptop and press the power button a few times. This should drain any remaining power from the laptop. Now plug in the AC adapter and try turning it on.
Let me know what happens,
Matt
Nov 14, 2007 | Toshiba Satellite M40-S417TD Notebook
Computers & Internet Logo
101 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
