Smb "no specified folder - Office Equipment & Supplies
2 Suggested Answers
support741
  • 337 Answers
SOURCE: Failed to send via SMB
What model copier? What error code? What OS?
Posted on Jan 30, 2013
Jan 17, 2013 | Kyocera Office Equipment & Supplies
No specified folder error
when setting up scanning to smb check the file path you are sending the document to. it is easier to store the folder on the c:\ drive under scans. Also ensure you have the correct username and password for the pc that has the file stored on it and set the NTLM setting to accept v1/v2.
Jan 10, 2013 | Konica Minolta Bizhub C224 Color Copier...
Will not connect to mac from dell pc?
Is your firewall turned on your dell PC?
did you setup your mac for sharing with smb?
you can turn smb on by going to apple>system pref>sharing>file sharing> options and click the check box for share files and folders using SMB( windows)
Feb 26, 2011 | NetGear WNR2000 Wireless Router
I use on my PC (Acer/Compac) My Pictures/Adobe Photoshop for the pictures I have. I have gone into the Properties section to add more information on each individual pictures. I than burned the photos...
  • When you go to the Connect to Server dialog, you may browse the names of computers that are on your local subnet.
  • You can connect to a server via its IP address or DNS name. If it is required or more convenient in your environment, you may also use other valid URL formats, such as:
    smb://ServerName/ShareName smb://DOMAIN;User@ServerName/ShareName
  • The name of the "share" (the shared disk, volume, or directory) must be specified. You will not be prompted for it.
  • You cannot type spaces as part of the share name when connecting. In place of any space in the share name, type: %20 .
  • When troubleshooting a connection issue, you can ping the IP address of the Windows PC using the Mac OS X Network Utility application (in the Utilities folder). A successful ping verifies a TCP/IP connection between the two computers. This is an important first troubleshooting step when there's no response or a timeout for a connection attempt, since SMB connections involving a Mac require TCP/IP. However, a successful ping does not mean the SMB service is also working or available.
  • Check Microsoft support resources for information about setting up file sharing on your Microsoft Windows-based computer. These may include Help files installed on your PC or the Microsoft online Knowledge Base. For example, see this article for Windows XP information: How to use the Simple File Sharing feature to share files in Windows XP.
  • When troubleshooting an SMB connection issue, use Console, which is located in the Utilities folder. These Console logs may help advanced users identify an issue: private/var/log/samba, private/var/log/kernel.log, system.log . Note that some log files only appear when logged into Mac OS X with an administrator acccount.
  • If you are connecting to Windows XP, make sure that the Internet Connection Firewall settings are not interfering with your connection. SMB uses ports 137, 138, 139, and 445. These ports should be open on the Windows XP computer. This may require "Advanced" configuration of the XP firewall.
  • If you are connecting to a Windows SMB resource, check to see if the firewall is blocking TCP ports 137, 138, 139 and 445. After trying the above steps, you may perform advanced troubleshooting by inspecting log entries in the Event Log of the Windows SMB resource (if you have access to it), and/or the Mac OS X computer's relevant logs in the Console application. If those steps do not help identify the issue, or you do not want to perform advanced troubleshooting, than you should contact your network administrator. It may be necessary to contact your network administrator in some situations in order to grant access to your Mac from the SMB resource, or its host network configuration.
  • Mac OS X uses SMB only over the TCP/IP protocol, not the NetBEUI protocol.
Dec 29, 2010 | Compaq Computers & Internet
Unable to access scan folder of Toshiba e-Studio 232 scanner from windows 7 system
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password. Click Network Click SMB Session Click SMB Session box In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server" Click Set button at top, then Save button, and the copier will reset.
Nov 08, 2010 | Toshiba Office Equipment & Supplies
How to scan to smb with konica minolta bizhub 250
create a folder on the pc you want to scan to and share the folder on the network. This must be done or the printer will not see the folder. Then register a new SMB user on the bizhub and direct it to that pc's IP and the shared folder.
Jul 23, 2010 | Konica Minolta bizhub C250 All-In-One...
How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Mar 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Can't scan to smb
in smb server, create a folder and give all rights, to that folder, if youre in domain, it may need you to use a password, so create a user and password and give rights that user in folder then go youre printer ip address, and add a contact, choose smb and fill in the fields. if error occurs, then choose details and you see whats wrong
Oct 30, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Scanning documents
You need to use the Scan to SMB function.
First create a folder, share it over your network.
Go to the MFP and under the scan to SMB enter the IP and path to the folder, enter the ID and password for the computer.
This will scan to the shared folder.
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
21 people viewed this question
jasbo
jasbo
