Intervlan routing using pfsense - Computers & Internet
What to do when chacha htc ask for pfsense portal
you are accessing a WiFi hotspot which requires login to get online, you simply need to ask the network administrator, or if you are in a cafe or a hotel need to ask at the reception for the internet username and password.
Aug 01, 2014 | HTC Status White/silver Unlocked At&t...
NAT session table is full
For each connection (TCP or UDP) that your firewall manages to NAT (ie network translate) keeps track on a in memory table. If it gets full means you've too many open connections. This is often the case when using P2P programs such as Torrent, eMule etc.
You can:
1) reduce the connection usage on the P2P application
2) reduce the connection timeout, in order to force the firewall to close stalled connections, recovering some free entry on the nat table
3) upgrade the appliance to something more heavy duty. Any box running pfSense for example could be a good choice: the web GUI is quite similar to the ZyWall one, but the software is both free and more powerful...
Dec 11, 2013 | Zyxel ZyWALL 70 Firewall
Cisco vpn disconnection through sonicwall firewall
This may sounds obvious but have you forwarded the correct ports through sonicwall for your VPN?
If you have, do you have any QoS running, it could be worth checking that VPN has priority over VoIP etc.
Do you get disconnects all the time or is it only during busy periods? You may be overloading your server, perhaps it's time for more RAM.
Oct 31, 2013 | SonicWALL PRO 2040 (01-ssc-5703) Firewall
How do you select most use of freeways to avoid back roads? My Magellan was easy to use in that regard.
Go to the Tools > Settings > Navigation > and press the button under Avoidances.
Use the arrow down and place a check mark in the box beside Unpaved Roads and then press OK.
Also, go to the Tools > Settings > Navigation > and setting the Route Preference to Faster Time will usually route using freeways. This is not always the case, as some secondary roads are paved and the unit will route to them if it calculates that this will be a faster route.
It is usually a good idea to familiarize yourself with an unknown route. This can be done after creating the route and touching the map screen. Zoom out to view sections of the route. Via points can then be added to modify the route as necessary.
Sep 28, 2011 | Garmin nuvi 1450 GPS Receiver
Hi I would like to set up a route and slightly
Routes can be edited to add or remove points by selecting the route and editing it while in the nuvi.
This can be done by going into the Tools > Routes, select the route and Edit then save. The route can also be edited by using the Where To? > Routes, select the route and Edit then save.
Sep 23, 2011 | Garmin nuvi 1450 GPS Receiver
I have a Belkin N1 wireless router connected to a broadband cable modem. I can connect to the internet via laptop & desktop with no issues. However when I try to connect to my work Sonicwall VPN it...
Firewall ports need to be opened. Log into router and turn on DMZ to your computer. Find your IP address on your machine 192.168.X.X and put that into DMZ settings or open up appropriate ports for VPN
Feb 11, 2010 | Belkin N1 Vision Wireless Router
High ping
Question, why are you using so many different routers? Sounds like you are causing a bottleneck in the network.
This is how I have my network.
Modem ---- PFSENSE Firewall (currently my DHCP Server) ------- Cisco Switch ------ Patch Panel ------- out to my Servers, computers and one wireless router. See only one machine is managing my IP addresses.
Buy a patch panel and run wireing to all the locations in the house or just run wireless.
Mar 31, 2009 | Linksys BEFW11S4 802.11b Wireless...
Routing problems
What version do you have?
Metroguide 5(?) & up do not auto route.
Mar 19, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Inter Vlan routing
Just For InterVLAN routing, Mark (enable) administration Access for ALL VLAN :P
Sep 18, 2007 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
