Question about Brother MFC 210C All-In-One InkJet Printer
How can solve unable to clean problem with my printer
  • Brother Master
  • 19,396 Answers
If the printer cannot clean the b printhead then remove printhead and soak it in alcohol, or use cleaner cartridge.
Posted on Mar 11, 2009
  • Ginko
    Ginko Mar 11, 2009
    The " unable to clean" error on Brother printers indicates that the printer had been unable to complete the clin head procedure, this can happen for different reasons.
    To start try unplugging the printer from main for five minutes, and see if you get the error back.
    Remove and put back in place cartridges , if you have differetn cartridge , then replace them.
    Check if you have paper or foreign objects stuck near the printhead, this can give you unable to clean error.
    Also a fully soaked waste ink pad inside the printer (not counter full, that gives a different error) can cause the same , in case the printer must be disassembled to replace waste ink pad.
    If that is not enough , try using a cleaner cartridge, or removing printhead and leaving it soaked in isopropyl alcohol overnight, in case that the printhead is really clogged.
Paper jam unable to print print 73 error how to solve it
I have same problem, the message make me wonder. I am very sure there is no paper tears in the printer. But then i have the answer from internet. I hope this answer can solve your problem too.
First shutdown your printer and open printer cover and find something like ribbon plastic transparant. becareful,clean that gently use wipe tissue or alcohol tissue. dont touch with your finger. hopefully it can solve your problem.
Oct 03, 2016 | Brother DCP-J315W Inkjet Multifunction...
"clean unable 46 " and see troubleshooting and routine maintenance chapter in users guide.
HI Gail,
Please watch this brother problem related video and solve your problem.
Still having Problem Then follow Us For Brother Printer Support
Mar 22, 2014 | Brother DCP 165C Compact Color Inkjet...
Brother error code dcp-j 125 unable to Init 50
hi good day! the printer is error 50 due to a paper or some sensor error.. open the printer, or dismantle, clean the sensor and wash the pump of water and change the waste pad of new absorber. locate the sensor under the pump, clean it of alcohol.
Mar 17, 2014 | Brother DCP 165C Compact Color Inkjet...
UNABLE TO INIT. 49 (BROTHER PRINTER MFC-J430W)
dear sir, My printer Brother MFC J430 shows unable to clean 49 in display I have found any solve or suggestion in youtube / Google please suggest me.
email. laskarnet2014@gmail.com
BAHAR LASKAR
SILCHAR, ASSAM
Jun 19, 2012 | Brother MFC 420CN All-In-One InkJet...
Unable to clean error 46 Printer Brother DCP-6690cw
my DCP 6690 printer causes problem unable to clean 46 how can i solved this ..............
Jun 12, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
How to solve the clean unable 46error of a BRother dcp-130c printer.
Clean unable 46 means you need a new flushing box. It's where the ink goes when it cleans the printhead, and yours is full. You need a shop to replace it.
Jul 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
How to solve Brother 115c printer : unable to clean
use this link it will help you it contains manuals, drivers, FAQs and troubleshooting for your Brother 115c printer..
http://welcome.solutions.brother.com/BSC/public/as/au/en/model_top/colormfc/dcp115c_eu_as.html?reg=as&c=au&lang=en&prod=dcp115c_eu_as
Jun 24, 2009 | Brother MFC 240C All-In-One InkJet Printer
When trying to print it says: unable to clean
refix your ink cartridge then try.also check there is not any paper jam.
Dec 25, 2008 | Brother MFC-3240C All-In-One InkJet...
Hp LaserJet 1200 Printer
open cover eject toner and toner flap cover open {spring flap cover} clean drum if your problem not solve so check fuser assy
teflon sleeve
most of your spot problem solve after you clean toner drum
otherwise replace toner drum or toner cartridge
Feb 27, 2008 | HP LaserJet 1200 Printer
Brother MFC 210C All-In-One InkJet Printer Logo
18 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
