Question about Toshiba e-STUDIO 282 Black and White Copier
I have a wrench code on my EStudio28 & machine went down-for days it has said periodic maintenance, can this be reset
  • Toshiba Master
  • 653 Answers
Periodic Maintenance will appear if the PM counter setting is reach.
Normally, it wouldn't affect your machine, just that the message will shown at panel.
U can enter setting mode 08-252 to, set "0" to clear the counter, or 08-251, set "0" to disable the PM counter.
If your machine having problem, totally cannot run, u can enter 08-253 to display the last 8 error codes.
Posted on Mar 11, 2009
The car with the wrench warning light is on what is the problem
that is a maintenance warning symbol
so run the fault codes to see it it refers to any sensor problem
check for a maintenance service period
Jul 20, 2015 | Cars & Trucks
Toshiba 2330C periodic maintenance code 00FF?
machine ON .....0+8
code is ....252.... press start button
value input is......0
press Enter Button
time for periodic maintenance is clear.
Apr 01, 2014 | Toshiba E-studio 2330c 2830c Color...
A wrench appears and 34a I don't know what that means and I don't have the manual, it happen two days ago. I put engine oil because it showed 15% oil.
That wrench is a maintenance minder indicator lettting you know that your oil's service life is at 15%, not that the level or amount is low. Have your oil changed and have the maintenance minder light reset.
Aug 24, 2011 | 2005 Honda Odyssey
My garmin nuvi 750 went dead when i got it to
Hello :
Resetting your GPS could solve the problem .
Here is how to reset your NUVI :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 17, 2010 | Garmin nuvi 750 GPS Receiver
Panasonic DP-8020P Machine Maintenance count reached.
yep. as long as the print quality is good and stable, and the toner consumption is good (8K to 10K of pages per bottle) you can just reset the maintennace count at f7-03 on service mode. probably your machine count reached at 120k. :)
Nov 02, 2009 | Panasonic DP-8020E Black and White Copier
Morning, LG WD1295FB error OE, plese advise
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. oe_led.jpg oe_lcd.jpg LED display models LCD Display Models Step 1: Check the drain pump filter. Step 3: Confirm that the washer is leveled properly. Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine. An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Oct 26, 2009 | Washing Machines
I am getting a wrench symbol and code P2.Can you tell me what this means
The p2 code is your rinse thermistor is bad,if you gain access in the back on the top right side you will see a probe with 2 wires going into the rinse piping.Use a 7/16 wrench and unscrew.Very easy to replace.When the machine goes into the rinse cycle the temp display goes up/down?The part is about $60.Part # 328994.I'm a hobart tech any ? let me know and please rate me.
Aug 21, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Copier will not operate due to wrench symbol
Hi the the wrench symbol appears when its time for maintenance depending of the type of service needed the copier will shut down, the only why to over come this is to call your service provider for maintenance they will replace what ever parts and or sevice thats needs to be done, they will then enter the code that is need to reset the wrench symbol..
Good Luck
Jan 27, 2009 | Panasonic FP-7735 Black and White Copier
Need to reset prevented maintenance code on Panasonic 7735 copier
okay, you need to press these three keys simultaniously
"user preset, ledger, and the number 3" you will enter the service F mode, then press 7 then the print button, then enter 22 then print then press 000 print, 000 print again and a wrench will lite up which means you just reset the maintenance counter. you then must press user preset and clear/stop key simultaniously to exit.
Thank You,
Mikey
Apr 04, 2008 | Office Equipment & Supplies
Toshiba e-STUDIO 282 Black and White Copier Logo
616 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
