Question about Brother LS-1217 Mechanical Sewing Machine
Brother sewing machine vx1120 Ithink won't pick up bobbin thread
I have tried retheading, cleaned bobbin case still won't pick up bobbin thread
  • Anonymous Mar 27, 2014
    the sewing machine won't pick up the bobbin thread
    Sewing machine won't pick up the bobbin thread
    Genius:
  • 1,066 Answers
Have you tried other thread and a different bobbin?  The tension screw on the bobin case could be too tight.
Posted on Mar 11, 2009
Brother VX1120. Was sewing just fine then 8 inches from finishing it just stopped. If I rotate the wheel the feet move but when I use the foot pedal they don't move.
Suspicions that the machine is clogged with thread, lint, debris. Thoroughly clean the bobbin area, removing all pieces of thread, lint, dust, etc. If your manual recommends oiling, do that as well. Whatever it is that is holding the moving parts is enough that the motor cannot overcome the problem but your hand is strong enough to move the parts. Continuing to try to force the motor to do so may damage the motor.
Jul 06, 2017 | Brother Sewing Machines
My bobbin on an xl3030 brother sewing machine will not doing to pick up thread
First try changing the needle then rethread the top and see if it picks up if it still doesn't I would then take out the bobbin and put it back in the bobbin case make sure that the bobbin is in the right way, when you pull the thread it should turn clockwise . Then replace bobbin case till it clicks. Try it and see if it picks up. You may have to do this more than once.
Apr 20, 2017 | Brother Sewing Machines
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
My janome wll not pick up bobbin thread
Did it pick up the thread before you removed the bobbin case?
May 07, 2014 | Brother CS-8150 Computerized Sewing...
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
Bobbin casing won't turn
Sounds like a timing problem, maybe. While you wait for an better answer you might consider checking some videos out on Brother timing: Here
Jan 23, 2012 | Brother Sewing Machines
Vx1120 won't pick up bobbin
I HAVE MANUAL AND WILL EMAIL TO YOU IF YOU LIKE.
Jun 07, 2009 | Brother Sewing Machines
Brother vx1120 machine bobbin jam
Rethread the whole machine. Make shure you raise the presserfoot before threading.
Nov 30, 2007 | Brother CS-8150 Computerized Sewing...
Brother LS-1217 Mechanical Sewing Machine Logo
347 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
