Question about Compaq (158165-001) DVD Drive
How to remove front cover to expose dvd drive Compaq 5000
  • 62 Answers
SOURCE: removing the faceplate
Hi, I can help you with this. Are you trying to remove the cd-rom drive bay plate or the front panel of the tower?
Posted on Sep 16, 2007
SOURCE: Replace CD-Rom Drive
solution: open front blue magnetic case door, look on either side of the power button, there are finger holes in the other blue cover.
lift out from bottom to top. this cover comes off, not the whole
case. inside find tabs next to cd drive, squeeze and pull out. note: the side sliders were they come out, they will come off the
cd drive when removed. it is easier to replace the top drive by removing the bottom drive, put in the top half way, then put bottom back in half way and slide them in together.
voice of experience. hope this helps
Posted on Sep 04, 2008
RescueTechLA
  • 2653 Answers
SOURCE: front cover removal
There are tabs that hold it in if I can remember correctly.
Look on the bottom of the case. It might help to flip it upside down.
Let me know if that works.
Best of luck!
Posted on Feb 25, 2009
wayneard
  • 1901 Answers
SOURCE: Found a FIC AZ31 MB manual which covers the
No manual, but did find this online info:
Compaq 5WV270 Upgrades
Also, here is the main support page:
Compaq 5WV270 Support
Hope this helps.
Thanks for using Fixya.
Posted on Sep 23, 2009
Testimonial: "I read the first link but all it has is the EULA. The second link has info but the video, etc is for a HP A430N. At least you found something. Thanks."
Brandonmxb
  • 115 Answers
SOURCE: how do I remove front cover
I would take the cover off then try and pop off the front from there. Don't be afraid to apply some serious force, that's what I had to do.
Posted on Dec 09, 2009
Acer Aspire Am3470g case removal
I also have an Acer Aspire AM-3470G & just swapped DVD drives trying to troubleshoot a problem. Remove the one side panel with the finger tab that gives you access to the system board/HD's, etc. No need to remove the opposite side panel. With the panel off, there are 3 black plastic tabs holding the front cover on. Release them so that the front panel pivots to the opposite side which also has 3 black tabs. Those tabs will release themselves as you pivot the front cover. You may need a bit of force to pivot the cover so be careful not damage the plastic tabs. You'll now have complete access to the DVD tray area. The DVD is held in by 2 exposed screws, there are none on the opposite side of the drive. Unscrew them, disconnect the power & SATA connectors & slide out the drive. If you replace the DVD drive, test the new one before you reassemble all the covers to verify everything works.
May 04, 2012 | Acer Aspire Am3470g-uw10p
How do I remove the CD/DVD drive from this computer? The layout inside is different from many desktops.
just pop off the colored plate and the clips are on the side. the drive will slide right out.
(1) take off the left side cover, (2) near the front, at the bottom of the internal drive cage is a plastic lever, flip it down, (3) now open the front plastic CD holder cover (the bottom gray plastic thing), (4) there are two finger holes at the bottom of the top plastic cover - pull the top cover loose (note if you're scared to put a lot of pressure on it, you can use a small flat screwdriver through those holes to lift back the two tabs holding the cover on), (5) with the top cover off, pinch in the two plastic tabs on the side of the drive you want and pull it forward (note disconnect the IDE cable (and audio if there is one) before pulling the drive too far out), (6) pull off the two side rails from the old drive (they just push in and pull out) - but note which rail comes off which side (I'm not sure if they can be inserted upside down or not, so just keep track of which one goes on which side), (7) push the side rails onto the new drive (note you have to really push hard on the metal part of the rail to seat it properly - you'll know it's not seated if the drive doesn't slip in easily), (8) slip in the new drive & connect the IDE and power (and audio if there is one)cables (9) install the top plastic frame, flip up the lock inside the case, then close the bottom CD cover thing, (10) enjoy the new drive. hope this helps you and please vote for me
Dec 04, 2010 | Compaq Presario 5000 PC Desktop
I have an old Compaq Presario 5109 desktop (5000 Series Presario), it is no longer useful for what I need it for, but I would like the DVD drive out of it, so far I can not find out how to take it out. ...
I would like you to download (Free) the, Upgrading and Servicing Guide, for the Compaq Presario SR5109UK,
(Will apply to your SR5109 desktop computer),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=3457899&lang=en&
On this page the file is the first one in the list.
Upgrading and Servicing Guide - 2.06MB
Left-click right on the file name.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name - Upgrading and Servicing Guide, it may take up to 30 seconds before you see the first page.
It may also take longer before the file has fully downloaded.
(Took 4 seconds before I saw the first page, and an additional 20 seconds before the file was fully downloaded. Medium speed DSL connection)
Page 12 has information about removing an Optical Drive. (CD/DVD drive)
Should you not be bale to download this file from HP Support, please state so in a Comment, and I'll lead you through it step by step.
(Computer unplugged from power. The Front Panel has to be removed, and the Side Cover. Then there is a locking arm you swing down to remove an optical drive)
Jun 12, 2010 | Compaq Presario 5000 PC Desktop
I am trying to find were to put the new hard drive in the compaq presario 5000
There are several extra bays internal. You need proper data/and power cables, possibly a "Y" splitter to give you access to an additional power tap. Also about 4 small machine mounting screws and or spacer shims if the HD is smaller than the available bay. The HD does not necessarily need to be mounted through the front bt the 5000 has removable bezels that exposed the xtra bays.
Regards
Apeal
Aug 21, 2009 | Compaq Presario 5000 PC Desktop
Manual showing how to remove DVD-ROM Drive from case for Presario 5000?
REMOVE CASE SCREWS FROM REAR CASE COVER.CASE COVER SLIDES OFF FROM FRONT TO BACK.DVD IS HELD BY 4 SCREWS TWO PER SIDE DISCONECT POWER LEAD AND RIBBON CABLE YOU GOT IT,RICHARDM69
Dec 02, 2008 | Compaq Presario 5000 PC Desktop
Compaq 5000 series JBL speakers
Hi Shockme17, sorry for late response I have been away. Gently remove the frame holding the material speaker cover by pulling it off from the top (the material speaker cover is just a push fit on the main body of the amp/speaker). Don't use any implement, you may damage the cover. Once you have worked the cover off iy will expose 4 screws holding the unit together. Remove those & the unit splits into two parts. JeffuH
Sep 05, 2008 | Compaq Presario 5000 PC Desktop
Front cover
Ca you please tell me what type of PC you have? Compaq, HP, Dell?
Thanks
Jack
Jun 13, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Removing the faceplate
Sep 16, 2007 | Compaq Presario 5000 PC Desktop
Compaq (158165-001) DVD Drive Logo
158 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
